Old 10-16-2017, 09:29 AM
Super Moderator
As has been mentioned already, but want I want to emphasize: the key to the RV-12 is SPEED CONTROL. Unlike in some other airplanes where excess speed and altitude can be aggressively corrected by cross-controlling (slips), it is not so in the 12. If you are at 65 on base leg, you are too fast. 60 or less on final makes for a really comfortable approach that looks right and feels right, if you practice. Otherwise, with any bit of headwind it will feel too slow. Plus, at those speeds it will slip very nicely on final if needed.
Enjoy the time coming down final. It's very relaxing.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 10-16-2017, 10:34 AM
luddite42 luddite42 is offline
Flame suit not needed.
The lesser performance in a slip has little to do with design or that anything about the design is inferior.
Right - I don't think either of us meant to imply anything inferior, just the observation that slip effectiveness of the -12 is on the low end of the spectrum when considering all types out there. And I agree about airspeed control, which is a common issue among pilots in general. I rarely see anyone at the flight school slip those Cessnas on approach, but when I do, they look like they're over 70KTS, which defeats the purpose by a large margin.
Old 10-16-2017, 12:34 PM
Loading the airplane with a steep bank to final has helped me shed speed when Iím high and fast. Like the others say getting the airspeed down before worrying about losing altitude seems to be the best approach. (Play on words not intended,)
Old 10-16-2017, 01:52 PM
XOverZero's Avatar
XOverZero XOverZero is offline
Default What makes for a decent descent?
My very limited stick time in a -12 is sufficient to confirm that it is indeed a wee bit reluctant to slow down. So that causes me to wonder about pattern technique in the part of the world I'm in, where being alone in the pattern is almost unknown.
When getting checked out in a Champ long ago, my instructor was adamant about holding 80 (mph) or better on downwind (better is better) so as not to, as he put it, "be backing into other airplanes." On that point he was right. Seems like there's always the standard issue Bonanza or Centurion sneaking up from behind.
So what's the mellowest routine in the -12 for coaxing it from 80 (kts) to 60 (or less) while descending through base and final, with it being inherently disinclined to do that?
John Halcrow
Irvine, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2019
Old 10-16-2017, 01:53 PM
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 10-16-2017, 02:04 PM
DaleB's Avatar
DaleB DaleB is offline
Abeam the numbers I pull the throttle to idle, one notch of flaps, pitch for 70 knots. Turn base, second notch of flaps, pitch for 65. Turn final, pitch for 60 and slow to 55ish coming over the fence. If I have to add throttle at any point I figure I did something wrong, but it happens about half the time. I'm still working on it - and if people have better ideas I'm all ears.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 10-16-2017, 02:35 PM
tomkk's Avatar
tomkk tomkk is offline
350 hrs on my -12 now and I'm still working the technique but that's pretty much what I shoot for although I hold off the 2nd notch of flaps until I'm on final.
One other thing that I found dramatically affected the power off deceleration and sink rate was the idle RPM that I set on the ground. I initially started at about 1800 and had a heck of a time getting it down. I reduced the idle RPM to about 1600 and the power off deceleration and sink rate were both significantly increased and that improved my landings considerably.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 10-16-2017, 02:55 PM
DaleB's Avatar
Ditto. I have mine set for about 1600 on the ground also. Once I mistakenly set it for 1800, and thought I'd never get the thing on the ground. Felt like my name was Charlie, and they'd just raised the fare by a nickel.
Dale
Omaha, NE
Old 10-16-2017, 02:56 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is online now
Talking
What's behind you does not matter. Plan you airspeed and altitude for your target 5-10 miles out since it does not like to slow down quickly. Use 800' pattern above runway and not 1000'. About 75 at numbers on down wind, pull all power, full flaps, 65 to base, 60 turning final, stabilize then at 55 knots on final unless you want to float and use lots of runway. I use a close pattern and dead stick all the way 95% of the time. If too high slip aggressively but try to keep it around 60, if short due to greater head wind add a little power to flatten descent and let speed increase slightly until you've made the runway.
Scott- 2018 dues paid
Got medical back, now building a 7A; N579RV reserved, new engine installed, doing FWF, instruments & finish painting.
RV-12 #120515, N319RV 1st flight 12/2015 now over 270 hours.
RV-9A, 536 hours sold, RV-7 sold, Kitfox sold
Old 10-16-2017, 03:05 PM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Yup...180 steep turn to final sheds both speed and altitude..
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
