Old 10-24-2016, 06:36 AM
challinan challinan is offline
Default Rivets in Rudder Horn Brace
Almost done with my rudder. Yahoo!
I can't for the life of me figure out how to set the four AN470AD4 rivets in the rudder Horn Brace R-00910. See the drawing here:
https://www.vansaircraft.com/pdf/rev...4/RV-14_07.pdf
page 12 of the PDF (or page 07-10 of the plans.)
I don't think a flange-nosed yoke would fit the corner rivets. I'm thinking I need to purchase or fabricate a custom bucking bar?
Any ideas?
Thanks.
Chris
Chris Hallinan
Punta Gorda, FL
RV-14A (N914CH Reserved)
* (VS, Rudder, HS complete, elevators in progress)
* Donated for 2016, 2017
Old 10-24-2016, 06:58 AM
Bootscooter's Avatar
Bootscooter Bootscooter is offline
I have just completed this part and used the Tungsten Mini Bucking Bar, it has become my favourite bucking bar to use, and wish I had got it a long time ago
http://www.cleavelandtool.com/Tungst.../#.WA4FBjJh3q0
Chad Boot
RV14 140331 VH-VNX. Flying
RV10 Standard Fuselage Complete
RV10 Empennage complete
RV-7 Slider Flying VH-VNZ
Sports Aircraft Assn Australia. Tech Councillor.
2018 Dues Paid
Old 10-24-2016, 07:29 AM
dclaffey dclaffey is offline
I just completed this section as well. I struggled with how to get to these and found that a longeron yoke on the squeezer was able to get to all but the bottom corner on the skin sides. For those 2 rivets I used a mini-tungsten angled bucking bar.
Old 10-24-2016, 07:50 AM
mturnerb mturnerb is offline
I was able to get these with the longeron yoke on a "main squeeze". It was tricky
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 10-24-2016, 08:39 AM
Carl Froehlich's Avatar
Default Tungsten bucking bar
This is the little jewel I'm using on the new RV-8 project. Worth its weight in gold. The ETBB04 model: http://www.tungstenbuckingbars.com/prices.html
It is small enough to fit in those places a standard bar will not, but still have the mass to buck.
Old 10-24-2016, 08:45 AM
Wow, you're making some serious progress, Turner!! Way to go!
Chris Hallinan
Punta Gorda, FL
Old 10-24-2016, 08:46 AM
Which one, Carl?
Chris Hallinan
Punta Gorda, FL
Old 10-24-2016, 09:00 AM
The ETBB04.
Old 10-24-2016, 09:09 AM
rapid_ascent rapid_ascent is offline
From figure 2 it seems like they intended for you to rivet those 2 pieces together before putting it together with the rest of the rudder assembly.
Ray Tonks
2018 Donation Paid
RV-7 Fuselage in progress
* Rolled the Fuselage
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 10-24-2016, 09:13 AM
JDBoston JDBoston is offline
Have you found this rectangular shaped one to be generally useful? I have this one:
http://www.cleavelandtool.com/Tungst.../#.WA4kzPkrKUk
But do wonder which one to get if I get a second one. Yes I know you never can have enough of them But at $100+ a pop two will suffice.
Opinions? I am working on the rudder right now.
Jeff
RV-14A
Status: Wings complete, Working on: Elevators. Location:MA
http://vans14a.blogspot.com/
