Old 04-11-2016, 09:03 PM
Av8torTom's Avatar
Default AOA
For those of you with AOA, assign a specific angle to each Vspeed. Hold that AOA and the Vspeed will follow. For example if Vx is 8 deg AOA, go to and hold 8 deg, and the airplane will settle at Vx some moments later and there's no under shooting or over shooting the airspeed. Very handy at a short field with trees at the end. This is really what flying AOA is all about, not just for stall warning.
RV-9A (empennage completed, both wings completed, fuselage and finish kit completed, ready to hang engine)
N677AT reserved
Superior XP O-320, 160HP
Old 04-14-2016, 03:39 PM
Soarandtow Soarandtow is offline
Default pdf report
Kelly please send me a copy as well mku2@hotmail.com
thanks
LD
LD Blake
Soarandtow
RV9 80% built 1000% Togo
Dues paid Donation made
N61LD reserved
Old 04-14-2016, 04:20 PM
ArVeeNiner's Avatar
ArVeeNiner ArVeeNiner is offline
thanks
LD
It has been sent.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
First flight: 5/28/12, Memorial Day.
Phase I Complete: 8/18/12!
2018 donation: complete
Old 05-09-2016, 08:26 AM
sibriggs sibriggs is offline
Default Copy of report
Please send one to me also, thanks Steve Briggs
Steve Briggs. RV9, G3x, G5, VPX, GTN625
Old 12-06-2017, 01:31 AM
rjcthree's Avatar
rjcthree rjcthree is offline
Default N183RC results
Thanks everybody for the help/info.
After IAS calibration and halfway through Phase 1, N183RC V speeds are as follows:
Vx = 75kt
Vy = 95kt
Vg = 80kt (Best glide defined as best distance)
Vg, 10 deg flaps = 75kt
The slope of the curves is very shallow around the respective optimal number, +/- 5kt on most V speed is within 10% of optimal. Based on the data, I could call Vy anywhere between 89kt to 98kt, because the curve is dead flat in the range, for operational purposes, I like the higher speed for cooling reasons. Coming out of a Warrior, the deck angle vs horizon at Vx is pretty mind boggling. AC is RV-9A, 1113 empty, o-320/160hp, fixed Sensenich.
Rick 90432
RV-9A tip-up, O320H2, Ellison, Dynon D180
First Flight 2017apr23 - Out of phase 1 2018jul07
2011-2018 VAF contributor
Dog is my copilot, rest in peace 2015APR28. I miss that dog.
Old 12-06-2017, 03:18 AM
terrykohler terrykohler is offline
Default CAFE Report
Try this for the RV9A performance report
http://cafe.foundation/v2/pdf_cafe_apr/rv-9a.pdf
Terry, CFI
RV9A N323TP
Old 12-06-2017, 08:38 AM
sirlegin's Avatar
sirlegin sirlegin is offline
6 years flying my 9A
0320 dual lightspeed, fuel injected, catto 3 blade
VNE Never Exceed Speed 210 mph
VNO Maximum Structural Cruising Speed 180mph
VA Maneuvering Speed 124mph
VFE Maximum Flap Extended Speed 95mph
Vy Best Rate of Climb 90mph
Vx Best Angle of Climb 80mph
Best glide speed 75-80mph
Vso Stall Speed, Landing Configuration 54mph
Nigel
RV9A-N113SQ
52F
Old 12-06-2017, 08:44 AM
brad walton brad walton is offline
I'm sure I'll be corrected if I'm wrong, but my recollection is that Vy equals best glide ratio and Vx equals minimum sink speed as well as being best angle and rate of climb speeds respectively.
Old 12-06-2017, 09:13 AM
sirlegin's Avatar
You are wrong, but correct me if I'm wrong
Nigel
RV9A-N113SQ
52F
Old 12-06-2017, 12:19 PM
moosepileit moosepileit is offline
The best climb/best glide and best angle/min sink are starting points.
FAA sez:
"This is often referred to as best glide speed and, on most airplanes, it will be roughly halfway between Vx (best angle of climb speed) and Vy (best rate of climb speed). Keep in mind that this speed will increase with weight so most manufacturers will establish the best glide speed at gross weight for the aircraft."
https://www.google.com/url?sa=t&sour..._D_osCZnW3dTaV
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
