Old 04-08-2016, 09:03 AM
ArVeeNiner's Avatar
ArVeeNiner ArVeeNiner is offline
Copies sent.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
First flight: 5/28/12, Memorial Day.
Phase I Complete: 8/18/12!
2018 donation: complete
Old 04-08-2016, 04:38 PM
sblack sblack is offline
For fuel flow deck angle you want the worst case (highest angle) which is Vx at light weight. But since the target fuel flow for the test is usually 150% of max fuel burn of the engine the deck angle doesn't have to be very accurate.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
Old 04-09-2016, 08:32 AM
rzbill's Avatar
rzbill rzbill is offline
So.. we are talking about calculating path through the air PLUS angle of attack plus or minus incidence angle in order to measure attitude at top surface of canopy rails.
Gas tanks should be nearly empty (for minimum head).
I think this test has little relevance to a fuel pumped system other than a yes/no answer on fuel flow which would mean there is a fuel system problem other than deck angle. The change in head requirements will be small compared to pump output pressure.
OTOH, This test is critical for gravity fed systems and the flow rate data would be much more variable and relevant.
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 710hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
Old 04-09-2016, 11:21 AM
A yes no answer on fuel flow is pretty important if you want to survive your first flight. And there are any number of construction errors that could reduce fuel flow for a pumped system.
A friend of mine bought the wrong electric fuel pump. There is one kind that has a bypass and one that doesn't. He didn't bother to do the fuelflow test and found out in the air that when he turned off the boost pump the engine quit. It could not run on the mech pump alone.
So this test is fundamental for first flight safety for any type of fuel system.
Scott Black
VAF dues 2016
Old 04-09-2016, 12:31 PM
rzbill's Avatar
You completely missed my point. Of course a fuel flow test is important before first flight. My point is that to expect a measurable fuel flow rate change due to attitude on an RV is not realistic.
Bill Pendergrass
Old 04-09-2016, 01:03 PM
BillL BillL is offline
Interesting how much discussion there is on an assumed test protocol wwith an assumed test objective. Unless that test is documented, then one can not effectively engage with the usefulness of the test. RZBill is right, flow is not a pass fail criterion, at least vs gravity vector angle. It is valid for pass/fail of a pump. 125% of TO fuel flow at minimum supply pressure to carb or FI is the tipping point.
Dave Prizio did an EAA webinar on unusable fuel testing and it was better than the AC to which it referenced. Having participated in a ground test, it is good to see if there is air in the system being pumped to the carb or to the injection system, and if there are any fuel leaks. A static 30 pis air pressure test is best for finding a leak, but it is prudent to enable an observation of same during a unusable fuel test. Neither Daves, or the AC, should be followed blindly. One should consider the location and effects of fuel pickup points in the tank to fully develop conditions for a model/plane specific test sequence.
A nose up, nose down test at minimum pressures, measuring fuel flow for cruise and max TO is simply a test condition for the unusable fuel. The suction test needed is to measure the absolute pressure to the inlet of the mechanical pump under the power stall nose up condition. Then using vapor pressure, one can determine if cavitation is likely to occur for the fuel selected. It may be fine for 100LL, but fail for 100% auto gas. Slip testing is also needed to complete the unusable fuel testing, but it will be a flight test, tricky as it is.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Old 04-10-2016, 08:17 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Agree, and I'd add that the worst case is actually full power, nose-high stall. That will have a significantly different deck angle than would a full power Vx climb.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 04-10-2016, 01:24 PM
apkp777's Avatar
apkp777 apkp777 is offline
Here are my numbers.
xo-320 RV-9
Vne
Never Exceed Speed
182 KTS
210 MPH
Vno
Maximum Structural Cruising Speed
156 KTS
180 MPH
Va
Maneuvering Speed
102 KTS
118 MPH
Vfe*
Maximum Flap Extended Speed
78 KTS
90 MPH
Vglide
Best Glide Speed
82 KTS
95 MPH
Vy
Best Rate of Climb
82 KTS
95 MPH
Vx
Best Angle of Climb
71 KTS
82 MPH
Vs
Stall Speed Clean
50 KTS
58 MPH
Vso
Stall Speed Landing Configuration
43 KTS
49 MPH
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 04-10-2016, 01:35 PM
Ya didn't think of that one.
Scott Black
VAF dues 2016
Old 04-10-2016, 03:57 PM
ka6dan ka6dan is offline
Hint
Before you do the V testing make sure your airspeed has been calibrated. Spent some time with stall and AOA before I established my airspeed indications were off.
Ka6dan
RV9A
Phase I @ X35 is complete
Paid My 2017 dues
