Old 03-25-2016, 08:36 AM
czechsix's Avatar
czechsix czechsix is offline
Default 120 deg dimple die?
Working on the ailerons, the plans call for using a 120 deg dimple die for the 1/8" holes in the main ribs at each end of the aileron. Apparently this is the correct dimple die for the CS4-4 pop rivets used in these holes.
I built my RV-8A years ago and I know it had CS4-4 rivets in some locations, and I've never owned a 120 deg dimple die set...I just used the standard 100 deg set. The rivets looked fine aesthetically and after a decade of flying they are holding up good as new. So I'm wondering if Vans (Scott?) or others have had problems using a 100 deg die with these rivets that I may be unaware of?
I see Cleaveland sells the 120 deg die...it's just another $39 + shipping...
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 03-25-2016, 10:43 AM
Nova RV Nova RV is offline
Yeah my aileron building came to a screeching halt when I saw the next step needed the 120 degree dies. Ordered from Cleaveland and moved forward. Not sure it it makes any long term difference but I'm trying to follow the plans.
Chris Moon
Leesburg, VA
RV-14A kit # 140243
VAF 2017 and 2018 paid
www.mykitlog.com/chrismoon/
Old 03-25-2016, 10:45 AM
The decision is up to each individual builder...
A CS4-4 will fit in a standard dimple but only the very bottom of the rivet head is actually in contact with the skin... there is a slight gap between the perimeter edge of the rivet head and the dimple.
Paint tends to not want to bridge this gap well, and the rivet head will be slightly above the point of being flush compared to using the 120 deg dies.
The rivets do aesthetically look better when the 120 deg dies are used.
There may also be a slight strength difference because of the ability for the rivet head to tilt slightly in the dimple, but I have not done any tests to confirm that.
Scott McDaniels
Hubbard, Oregon
Old 03-26-2016, 07:08 AM
KeithB KeithB is offline
I would add that there are countersunk CS4 rivets coming later - one key spot is the Canopy Decks (rails on top of longerons) in the Fuselage kit. I decided these were going to be very visible and went ahead and bought both dimple dies and the countersink for CS4.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, >300 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 11-28-2017, 02:41 PM
SteveT SteveT is offline
Default Also called for on page 07-04
Dimples for CS4 are also called out earlier, on Page 07-04 (rudder). Based on what Iím seeing as I research it, Iím going to get the 120 deg die from Cleaveland. Is this the one that youíre using?
http://www.cleavelandtool.com/mobile/120-degree-dies-for-1_8-pop-rivets/productinfo/DIECS4-4
Steve Thompson
Scottsdale, Arizona
RV-14 #140437 - building the empennage
N45KK reserved
http://www.airplanebuild.com
Old 11-28-2017, 06:51 PM
Looks right to me.
Keith Brown
RV-6A sold
Dues paid 11/2017
Old 11-28-2017, 07:02 PM
Bill Boyd's Avatar
Default Given how the rivet head angle is measured
...I would think the fit of a 120 degree rivet in a 100 degree dimple or CSK would be just the opposite of what Scott describes. As in, the outer edge of the rivet touches the shoulder of the dimpled hole and the part near the shank is not touching.
But I could be wrong - happens often.
I try to picture a flat-head "180 degree rivet" (AN470 if you will), how it would fit in a dimpled hole, and work backwards in my mind from there to 120 degrees. I'm just not seeing the mis-fit in the manner that Scott describes.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 11-28-2017, 07:36 PM
vernon smith's Avatar
vernon smith vernon smith is offline
I would think so as well, a 100 degree drill point is two 50 degree angles one on either cutting face, a 120 degree is two 60 degree cutting faces so the contact point with the 100 degree dimple would be on it's outer edge unless there is something about all this I don't understand. Seeing I was recently chastised on the forum as a naive newbie, I may be way off base
Old 11-29-2017, 10:52 AM
Bill Boyd's Avatar
Vern, we can at least go off to a corner and hallucinate together
So if we're right, why does the paint not want to lay right on these pulled rivets in 100 degree dimples? Or is that not a thing, either??
Bill Boyd
Old 11-29-2017, 11:04 AM
mturnerb mturnerb is offline
Wouldn't it be pretty easy to just fill the gap with some kind of epoxy or body filler and paint over it?
Turner Billingsley
RV-14A In Progress
N14VB Reserved
