Old 09-24-2015, 08:18 AM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Default Powering Stratux
I built the ADS-B marvel, the Stratux and it works (almost, I just have a small problem with Fltplan's GPS on Nexus but this belongs to another thread). So far I powered Stratux via the USB plug located under the avionics shelf but it is in competition with my Nexus tablet which is also powered this way. As the whole kit will end-up on the fuel tank where the antenna seems to work well, I am thinking of hacking the power out of the ELT. There is an easy access to power from the buzzer but the conductor seems a bit thin to suck up to 2.5 amps (and even more if I end up using 2 dongles on Stratux to solve my GPS issue). As my annual inspection is looming, it's a good time to figure this out. Any suggestion from you guys who have gone more in depth into the circuitry?
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 09-24-2015, 10:09 AM
Raymo's Avatar
Raymo Raymo is offline
Have you considered adding power ports to the panel?
http://www.commitlift.com/usbchargers.html
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 09-24-2015, 11:21 AM
WingedFrog's Avatar
Yes I have. It's probably going to replace the cigarette lighter outlet for which I have no use in my RV-12. In this regard your product is interesting, thanks.
Sport Pilot
Kit # 120395 N124BX
EAA 1114
Old 09-24-2015, 12:59 PM
As I recall the 12V socket stays hot even with the master off. Be careful to not leave something plugged that will drain your battery when parked.
Old 09-24-2015, 01:50 PM
WingedFrog's Avatar
Good point Rich, thanks for the warning.
Sport Pilot
Kit # 120395 N124BX
EAA 1114
Old 12-06-2017, 04:58 PM
jrich jrich is offline
I have the D-180 configuration. So, to gain 12v power, cut off with the master switch, where do I go to add a new 12v power wire to power up anything inclusive of the Statux or ADS-B out equipment that will draw 3 - 5 amps?
Old 12-06-2017, 05:14 PM
DaleB's Avatar
DaleB DaleB is offline
I also have the D-180 panel. I simply moved the wire feeding the 12V power point from the hot side of the master relay to the switched side, and replaced the 12V power point with a dual USB power plug. Now it's switched on by the master.
I'm sure there are other suitable ways to do it, but that's what I did.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 12-07-2017, 08:56 AM
John-G John-G is offline
If you are interested in finding a convenient power source in the vicinity of the instrument panel, there is a spare unused +12 volt source on the back of the AV-50001 switch & fuse module on pin 6 labeled "Extra" on the prints which is powered off by the master switch. I needed an extra power source so just added a wire to pin 6 of the connector that plugs into the back of the switch and fuse module ... presto instant additional power.
Caution: The Extra circuit is unprotected ... so you will need to install an inline fuse for circuit protection. A couple of years back I called Van's and verified the trace on the module was rated to 5 amps even though it is shown on the prints at 2 amps .... (visually looking at the "Extra" trace on the module it appears to be as wide as the traces used for the 5 amp circuits).
Happy flying,
John
www.dogaviation.com
Now Flying!!
Dues paid until September 2018
Old 12-07-2017, 03:47 PM
h&jeuropa h&jeuropa is offline
To convert 12v to 5v for my Stratux, I am using this converter from DigiKey. It's inexpensive ($8.50) and no noise in the radio.
DigiKey P/N 1597-1243-ND
It is a Speed Technology, CPT-C5 converter.
Jim Butcher
