Old 06-22-2015, 09:00 PM
Dennis Harm Dennis Harm is offline
Default Static line
New builder ? On page 10-22 I riveted theSD-12-BSLF static source rivet and the stem broke off in the rivet can this be drilled out or do I need new rivets? Thanks in advance Dennis.
Old 06-23-2015, 12:10 AM
Use a 1/16" pin punch to drive the stem out of the rivet while someone holds a heavy bucking bar beside the rivet.
Scott McDaniels
Hubbard, Oregon
Old 11-14-2017, 08:37 PM
coffeeguy coffeeguy is offline
Default Instructions
Does anyone have an electronic version of the static air system instructions referenced in step 1 on page 10-22? It says "Follow the 'Installing the Static Air System' instructions included in the Static Air Kit to install the Left and Right Static Sources into the F-01473-L & -R Side Skins as shown in Figure 1 and on Page 10-19, Figure 1."
My static air kit had instructions for an RV6 electric flap system or something like that. I'm not sure how to rivet the static port, especially given the comment by Dennis. I figured it was just a pull rivet, so I tried it on one side and had the same issue with the stem staying in the rivet.
Jeff Dingbaum
RV-14A empennage, wings
Cherokee 180
2018 dues paid
Old 11-15-2017, 05:25 AM
Default RV14 static port
Jeff have since drilled out port rivet and went with Cleveland’s static port. Not flying yet but would be interested if anyone has used them and how they worked out thanks Dennis
Old 11-15-2017, 08:18 PM
Thanks Dennis,
I looked at the Cleaveland kit too, but in the end I thought I would just go with the stock static kit. That may change, though!
Jeff Dingbaum
Cherokee 180
2018 dues paid
Old 11-16-2017, 06:47 AM
rleffler's Avatar
rleffler rleffler is offline
They work fine and are used quite frequently in RV's. Their original version had some issues, but those were resolved about a decade ago.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
