Old 12-04-2017, 08:50 AM
sblack sblack is offline
Originally Posted by Ex Bonanza Bucko View Post
Thanks guys. I guess I should have added that I am not interested in Steam gages because I like them but because they don't fail like glass cockpits are bound to.
EBB
Sure they do. All the time. They are mechanical devices with gears and wheels, like a pocket watch. Also, pitot/static tubes get contaminated, in which case a steam gauge or efis will stop working. So if you put in backup ASI and Alt hooked into the same pitot static lines, your reliability won't really improve. If your efis has a back up power source I bet it is statistically more reliable than an ASI, especially the cheapo Falcon ones.
There is a lot of prejudice out there, based on fear and superstition, but not hard data. "I feel more comfortable with X" doesn't mean X is safer.
Bottom line is, if you really want to be safe, learn to fly without ASI and Alt. It is not really that difficult. It was part of my initial training prior to solo. Personally I seem to land better without them. I guess I am more focused on visual cues. That extra half hour of training is cheaper than backup steam gauges.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2016
Old 12-04-2017, 07:09 PM
N941WR's Avatar
N941WR N941WR is offline
If you really want a backup, put a Dynon Pocket Panel in the plane for your back up.
Since you are going to be flying as an LSA (day VFR), you should have no problem landing if the SkyView went dark.
If you add a backup handheld GPS to the Pocket Panel, then you can aviate and navigate but you still won't have engine instruments.
How much weight do you want to add in backup instruments?
The truth is, the SkyViews are amazingly reliable.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-05-2017, 07:50 AM
yankee-flyer yankee-flyer is offline
Default First thing I did after
Getting my airworthiness slip and flying 5 hours was to add steam airspeed and altimeter and a slip indicator. I used fittings from one of the common suppliers and put T's into the lines behind the panel. Took very little time and works like a charm. Thinking about a whiskey compass for the time when the D180 goes black.
Wayne 120241 458 hours
Old 12-05-2017, 08:07 AM
Mel's Avatar
Mel Mel is offline
There seems to be a misconception here that an ELSA cannot be modified until phase I testing is completed. That is not the case, An ELSA can be modified immediately after certification. I know this is a minor point, but let's keep things clear.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 12-05-2017, 09:31 AM
EXflyer EXflyer is offline
The going black part makes the steam gauges valuable as they do not rely on batteries or an alternator. Been flying on and off since 1963 on steam gauges, many times with the basic, needle ball and airspeed. No fancy digital gauges for the engine even on injected ones never had a problem.
Just my take on things, I would have basic ones like mentioned if I were to build again.
