Old 10-02-2013, 09:27 AM
Ex Bonanza Bucko Ex Bonanza Bucko is offline
Default Backup Steam gauges
I will soon (I hope) be flying either a new S-LSA RV12 or a professionally built E-LSA. I am old fashioned--lotsa CFI, IFR, long range and Mexico Flying. I am used to steam gages....they are all old friends.
I think I would like to have backup steam Altimeter and Airspeed in any plane with a "glass cockpit." So do you know if there is a restriction on those in either a SLSA or an -ELSA.
I will go to Aurora to test fly an RV12 next month and I'm sure I can get an answer to these questions there but I'd like your comments in wisdom first.
EBB
Old 10-02-2013, 09:49 AM
664781 664781 is offline
E-LSA won't be a problem after the time is flown off. S-LAS will be a lot harder but not impossible. Lots of paperwork with the FAA or a DER going S-LSA just like the spam cans today.
Kurt Lohmueller A&P
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 10-02-2013, 10:07 AM
txaviator's Avatar
txaviator txaviator is offline
I'm going back in my memory bank, from things Mel has mentioned over the years. I believe I am correct here:
Unless you take the S-LSA aircraft and re-register it as an E-LSA, I don't think it is permissible. However, as others mentioned, if you buy an E-LSA, after the inspection and after the hours are flown off, you can add them.
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 10-02-2013, 10:14 AM
Mel's Avatar
Mel Mel is online now
Gary is correct. No changes can be made to SLSA without written approval from the manufacturer. The operating limitations state that any unauthorized changes will make the airworthiness certificate invalid.
SLSA can be re-certificated as ELSA. After that you may make any changes you like.
Actually SLSA is more restricted than Standard Certificated aircraft.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 10-02-2013, 10:20 AM
f1rocket's Avatar
f1rocket f1rocket is offline
EBB
Really, you sure you want to do that? I know old habits die hard but I'm pretty sure I could fly my -12 just by looking out the window.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 10-02-2013, 11:20 AM
rleffler's Avatar
rleffler rleffler is offline
Plus many of the current EFIS offerings have a six pack screen. I've found that to be a great transition tool. One screen on six pack and the other on the standard tapes. Then transition as soon as you're comfortable with the new formats.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 10-02-2013, 11:41 AM
Bill_H's Avatar
Bill_H Bill_H is offline
Fly with the SV for 30 minutes. You will never want to go back. Question on SLSA - Does written permission from Vans to - say add an altimeter -'mean that they are essentially approving an STC? Would they just have to write "Sure, do that" or provide detailed drawings of exactly how? Or could they just say "Sure, have it done by a certified mechanic following standard aircraft techniques per FAR XXXXX." Or is this such a new area that the answers are unknown?
Old 10-02-2013, 11:47 AM
N941WR's Avatar
N941WR N941WR is offline
It is a LOT of work rerouting the pitot and static lines up to the panel. The sensors for the SkyView's pitot and static lines are not usually installed in the panel.
As the others have said, fly with the SkyView, it is really intuitive.
(When I reworked my panel and installed the SkyView, I had to drill up the floor boards and rout the lines into the tail cone.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-02-2013, 12:17 PM
txaviator's Avatar
Exactly! The Skyview pitot and static connections in an E-LSA or an S-LSA RV-12 are mounted way back in the upper tailcone. It would be a bear to do this after the fact, not to mention routing the tubing through the already quite full RV-12, center tunnel!
Gary Robertson
Arlington, TX
Old 10-02-2013, 12:20 PM
sandpiper sandpiper is offline
There are no STC's for S-LSA. However, there is a formal process required and some manufacturers charge. In the end, you get an LOA (Letter of Approval) which could be aircraft specific or fleet wide.
Provided the manufacturer agrees with your request.
John Horn (donated for 2018)
Independence, OR
LSRM-A, CFII
Rotax Service, Maintenance, and Heavy Maintenance Trained
Building an RV-12, N7878H reserved
Flying a Flight Design CTSW
