Old 08-30-2013, 09:10 AM
yankee-flyer yankee-flyer is offline
Question Packing MAtco Bearings
It's about time to clean/re-pack the wheel bearings. Last time I used the "standard" Handy-Packer, but it seemed to take a LOT more force to push the grease up through the Matco bearings than with standard bearings. Am I imagining things or should I be doing something different?
Wayne 120241/143WM
Old 08-30-2013, 09:14 AM
DonFromTX's Avatar
Are you certain you are using the Matco recommended grease? Mine loaded quite easily with a bearing packer, but that Matco recommended grease has the viscosity of motor oil!
Retired US Army Officer
Old 08-30-2013, 10:02 AM
NASA515 NASA515 is offline
I thought the recommended grease was Aeroshell 22 (RV-12 MM pg 1-11)?
Bob Bogash
N737G
Old 08-30-2013, 01:40 PM
Default Me too, Bob
Aeroshell was what I'm using
Wayne
Old 08-30-2013, 01:51 PM
Your difficulty is caused by the bear race being closed off on one side by the integral seal.
I believe Matco sells a needle attachment for a grease gun, that can be inserted between the rollers. When the gun is pumped the new grease pushes the old grease out the open side.
Scott McDaniels
Hubbard, Oregon
Old 08-30-2013, 06:43 PM
Back in my teens we didn't have anything fancy so we learned to work the grease in by hand. (The horse didn't seem to mind.). :-)
Old 08-31-2013, 04:09 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default Shelf life
Wayne 120241/143WM
Aeroshell 22 grease has a limited shelf life and needs to be retested every three years. The color is intially (light) tan, however it will darken and thicken with age. I experienced some difficulty packing my bearings the first time because of an older grease tube that was donated to me by the local helicopter company (they moved-on to a different grease type). I subsequently bought a fresh tube, and problem solved; the L'Isle Handy packer worked like a charm with the fresh grease.
The color difference was very noticeable. When/where did you buy your grease? I seem to recall that Shell has date codes on the grease tubes now.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
over 900hrs tach.
Old 08-31-2013, 05:49 AM
Walt's Avatar
Walt Walt is offline
I use Mobil 28 for all greasing, generally considered superior to the Shell.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 08-31-2013, 07:22 AM
DonFromTX's Avatar
Me too, it is red color and I was not aware of a shelf life, will have to check that out.
Old 11-06-2017, 12:27 AM
rgmwa rgmwa is offline
What's the best way to remove the old grease prior to re-packing the bearings?
rgmwa
120346
