Old 08-18-2013, 01:56 PM
alpinelakespilot2000 alpinelakespilot2000 is online now
Next time I would use hinge and abandon the screws altogether. Looks nicer and faster to get the tips on and off. Agree though that #4 are way too small. I even wear out the heads of a few #6's every time I take off the tips.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 08-18-2013, 02:08 PM
RV6_flyer's Avatar
Originally Posted by Stoo View Post
I used the Cleaveland kit with 4-40 screws.
http://www.cleavelandtool.com/Stainl...ctinfo/WHS220/
Stewart Willoughby
6, finishing
I used the same thing over 16-years ago and like them. (4-40 screws to mount wingtips)
I have read others that have NEGATIVE comments about the #4 screws. After almost 16-years and 2,700 hours of flying, I have yet to have a problem with any of my #4 screws.
I always use a driver drill with removal high quality tip bit, or a screwdriver with a high quality removable tip. If using a non-power operated driver to remove the screw, the screw driver is usually a "Snap-On" ratcheting screwdriver.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 08-18-2013, 05:10 PM
Stoo Stoo is offline
Originally Posted by instructor_bill View Post
then also go to microfasteners.com and buy #4 torx screws and you have a really nice, low stripping solution.
I found that the screws that came with the cleveland tool kit stripped very easily. I tried everything including flattening the tip on a high quality new screw driver tip to get a deeper bite in the screw head-- still stripped.
torx is the way to go.
Yes, I did that! Torx are not perfect in these small sizes, but they are definitely better than Phillips!
Stewart Willoughby
6, finishing
Old 08-18-2013, 05:45 PM
For those of you using stainless screws, a dab of beeswax in each of the nutplates will make the screw easier to remove, and helps in the stripped Phillips head arena. Stainless tends to gall in the nutplates and becomes hard to remove.
If using a power drive run at slow speed also.
Toilet bowl sealing rings are a prefect source of beeswax----one ring should last you a lifetime------Jay Pratt excepted
Old 08-18-2013, 07:58 PM
RV6_flyer's Avatar
That (beeswax) is what we (former employer that had Aircraft in its name) used on the thread of the screw. We just pulled one side of the screw thru the wax then ran it in. "DoAll" and other solid waxes work just as well from using what ever I had laying around over the years when Bee's Wax was not at hand.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Old 08-18-2013, 08:39 PM
DaAV8R DaAV8R is offline
That's kinda gross. Do you just set the toilet on some 2x4's while your using the ring?
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 08-18-2013, 09:54 PM
Snowflake's Avatar
Seriously, since I first saw this done, I don't understand why it's not the standard way to attach wingtips. Still considering if it would be possible to retrofit mine.
http://www.matronics.com/wiki/index....ps_with_Hinges
Rob Prior
Old 08-18-2013, 10:28 PM
rocketbob's Avatar
rocketbob rocketbob is offline
I put the tips on my Rocket with hinge. I can remove or reinstall a wingtip in under 30 seconds. Looks nice and clean.
Only thing with the hinge is you have to take out the slop inherent with hinge. Simple to do with a hammer and anvil to stretch the hinge on one side so it fits tight.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Don't believe everything you read on the internet. -Woodrow Wilson
Old 08-18-2013, 10:53 PM
hydroguy2's Avatar
hydroguy2 hydroguy2 is offline
I'm too clumsy with a screw poker, so went the hinge route.
It's just one Dam job after another
Brian, N155BKsold
Old 08-18-2013, 11:32 PM
Ironflight's Avatar
VAF Moderator / Line Boy
OK, so who is going to be the first to write me an illustrated guide to the hinge method for Kitplanes?
You can PM me if interested....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
