Old 10-03-2017, 11:45 AM
mike newall's Avatar
mike newall mike newall is online now
Micro Molex solution - slice them off, use gold D Sub pins and sockets and a bit of heat shrink.... Move on
Donated twice in 2017
Old 10-03-2017, 06:39 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Originally Posted by Raymo View Post
Agree. I tried using someone's double crimper (crimps the wire and tefzel coating at the same time) but it didn't go well. Sometimes you have to trim off a bit of the tabs that go around the wire coating to avoid breaking them off due to being too long.
I think that is because the tooling assumes a thicker commercial PVC type insulation.
Our Tefzel stuff is pretty thin compared to most insulation.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-04-2017, 07:48 AM
Or just use the Dsub housings. In any case, Dsubs are much better quality and fewer headaches down the road. The Dsub pins are rated up to 7 amps each (5A if you want to be ultra conservative), and you can use 6" pigtails to parallel multiple pins if you need higher current.
If you insist on using Molex style terminals, know that the industrial quality crimpers (at least the ones I have access to, that spent their previous life in a GM/Packard/Delphi wire harness plant) do a 'B' crimp on both the wire and the strain relief (insulation). The insulation crimp is just a slightly bigger version of the wire crimp.
Old 12-03-2017, 08:53 AM
MED MED is offline
I have come to agree with this position. I find I really donít like or trust mini Molex connections!
MED
140236
N435MD reserved
Old 12-03-2017, 09:38 AM
rongawer's Avatar
rongawer rongawer is offline
Default Iwiss Crimper
With the right tool, the micro molexís go together fairly easily and are a reliable connector thatís easy to assemble and disconnect. The right tool for this job is available for about $23 on Amazon. It can also do the hitachi or dupont crimps as well. I do agree that D-Sub connectors are a very solid choice, but the micro-molex (and generic others) are much smaller and easier to route if needed.
IWISS Crimping Tools for Dupont Professional Pin Compression Ratcheting Modular Insulated Terminal Crimper Pin 2.54mm 3.96mm 28-18AWG 0.5-1.0mm2 with Wire-electrode Cutting Die https://www.amazon.com/dp/B00OMM4YUY/ref=cm_sw_r_cp_tai_4MbjAbAX9C4W1
Ron Gawer
- RV12, N975G, SN 120840, Build in progress...finishing up.
- BE58, N1975G, stimulating the economy one flight at a time.
