Old 12-05-2017, 01:21 PM
mfleming's Avatar
mfleming mfleming is offline
Question Delrin Aileron Stop
While doing research on fabricating the Van's aileron stop I came across info on making the Delrin stop. Looked great, simple, easy and adjustable!
So I ordered several diameters of Delrin stock...Others had used " stock but my gap looked pretty big. Using " stock I fabricated a stop with the aluminum bushing pressed into it.
The " stop isn't event close to touching the bracket?? Is there really that big of difference in hinge dimensions between projects? It looks like I will need at least a 1" stop.
Am I doing something wrong??
The gap is really more than this photo shows, because the aileron is resting against one of the hinge bolts on the outboard end.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 12-05-2017, 02:59 PM
jmjula's Avatar
jmjula jmjula is offline
I made mine using a hole saw in a sheet of delrin of the right width, then I "lathed" it to the perfect diameter using a cordless drill and the bench scotch-brite wheel. I don't remember exactly what diameter I ended up with, though visually looking at your pictures I believe mine are slightly bigger. That said, each side is a different diameter to get the deflections to match right and left, so I do know there is a variance.
EDIT: measured mine, they are both about 15/16" in diameter, and I have mid-range deflection to limit the sticks contact with the throttle and mixture
James Jula - CFI/II/MEI - N713JL RV-7A First Flight 10/12/15 - "What is chiefly needed is skill rather than machinery." Wilbur Wright, 1902
Old 12-05-2017, 04:50 PM
mfleming's Avatar
Great tip...
I'm thinking I must have done something wrong because even a ⅞" delrin spacer would fall far short of stopping the aileron
With the aileron full up and no stop, I measure 32°...That doesn't seem right.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 12-05-2017, 04:56 PM
Bruce's Avatar
Bruce Bruce is offline
Michael,
I used a -3 bolt and 2 big washers and then ground on wheel.
Can't remember the washer size but the 1" size sounds right.
You should have a stack of the washers in the kit.
You have to put on both sides.
Then you can get the right measurements.
Everything has to be hooked up.
Bruce (BOOMER) Pauley
Kathy (KAT) Pauley
RV 7A--"MISS MARIE"--- N177WD (SOLD FLYING)72742
VAF #582-----------------EAA LIFETIME MEMBER
EX -KC-135A -------------BOOM OPERATOR #3633
VAN'S FLIGHT------------#6930
See you in OSHKOSH
http://www.mykitlog.com/users/index....ley&project=84
=VAF= 2006-2018 DUES PAID
Old 12-05-2017, 06:04 PM
BillL BillL is offline
Default Just did this today
It seems I totally missed the stop and some friendly builders found the deficiency. I used some wax to measure and came up with .490" for left and .560" for the right. I would not venture to comment on what is right.
You might check Mike Bullocks website - rvplane.com to see what size he had.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Old 12-05-2017, 06:38 PM
mfleming's Avatar
Very cool trick...
So the measurement of .490 for instance, was the distance needed to be bridged and the diameter of the stop would be roughly double that?
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 12-06-2017, 06:00 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Take black Delrin
Take black Delrin, it is better regarding UV stability.
The black pigments are preventing the UV ray's to enter the material.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 12-06-2017, 11:37 AM
bruceh's Avatar
bruceh bruceh is offline
I think I used 7/8" diameter on the RV-9A.
I've still got a bunch of material left, so if anyone needs some.....
Good instructions on Smitty's site.
Bruce Hill
RV-9A N5771H flown over 600 hours!
http://www.overthehills.com/RV-9A-Project
APRS Tracking for KJ6YRP and New Flying Blog
2018 VAF donator
EAA Tech Counselor
Old 12-06-2017, 12:07 PM
Default Deal
Bruce,
I will take some of that extra delrin.
John S
Fuselage 30%
Old 12-07-2017, 06:32 PM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by mfleming View Post
Great tip...
With the aileron full up and no stop, I measure 32...That doesn't seem right.
Isn't that what the manual gives for Max Up deflection?
Design Travel in degrees Maximum Up/Down Minimum Up/Down
Aileron 32/17 25/15
