Old 11-09-2017, 02:59 PM
sjhurlbut sjhurlbut is offline
Default Changing from Vans to Airfoil gear
Anyone drill the standard Vans gear in place and then swap out for the Grove Airfoil gear at a later time? Is this a simple unbolt-bolt swap?
Looks like the production of the airfoil gear is a very long time and I need to proceed.
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - building
Old 11-09-2017, 03:30 PM
rv8ch rv8ch is offline
I doubt it will be much different - the main thing I noticed is that the grove gear is thicker - I believe that the holes are in the same place.
I'll bet you a nickel you won't change them out once you have installed the van's gear and are flying.
Mickey Coggins
http://rv8.ch
