Old 03-13-2018, 06:44 AM
Michael Henning Michael Henning is offline
Default Phone activated switch
I purchased a U-Phone-It switch from FST LLC(through ACS). It is extremely well built, and the customer support is outstanding. I had a question on Sunday, and texted the number in the manual. I got a call back shortly after that with the answer. There are two outlets on the unit and can be operated separately or even staged. I have it set up to turn on oil heat, then 4 hours later to turn on cabin heater for the final two hours. All run times are programmable, and the unit can be queried to see what outlets are on, and to check signal strength. To simplify the operation, there is a free app. The SIM card is $70 a year for unlimited access, no WiFi needed. It works great👍
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 03-13-2018, 09:04 AM
Jpm757 Jpm757 is offline
I also purchased the U-Phone switch last fall, since no wi-fi available at my hanger. This little gadget works great, no problems. Check to see if you have AT&T service available where you place the unit. Owner, Karl Bumpers provides excellent support.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 150+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub
2018 dues paid.
Old 03-13-2018, 12:23 PM
My house typically has poor coverage, it I had a signal strength of “5”, which was good enough. Hangar has a signal strength of “12” out of 18. I am impressed with the quality and forethought put into the design and operation of the unit. The SIM card can be swapped out to a different carrier, but $70 a year is cheaper than T-Mobile, so I will stay with ATT.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 03-13-2018, 02:13 PM
T-Mobile has a 30 text/month plan for $3/month.
See http://www.vansairforce.com/communit...0&postcount=17
Hinckley, Ohio
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2004
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 391
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
