Old 03-12-2018, 01:21 PM
rleffler's Avatar
rleffler rleffler is offline
Originally Posted by az_gila View Post
If I read your blog pictures correctly, the 1/16 Fibrerfrax is sandwiched between the two skins (SS and original belly aluminum) by the same rivets that attach the skins to the fuselage ribs.
Wouldn't having this layer of Fiberfrax in the assembly screw up the structural integrity of the skin to rib riveted joint?
I don't know how either Mike or Kyle assembled theirs, but I would not use the rivets in the plans to ensure no compromise to structural integrity. I would off set rivets lines dedicated to the stainless plate.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-12-2018, 02:10 PM
That's what I did. The primary structure is per plans. The pop rivets for the overlay are just there to attach the stainless sheet.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-12-2018, 04:06 PM
ppilotmike's Avatar
My belly shield does, in fact, use the rivets that attach the ribs to the bottom skin. I used rivets slightly longer than the ones called for by the plans, in order to get the proper diameter/height on the shop head.
Keep in mind, that 1) my belly shield is not the full length of the bottom skin, only the first 18 inches or so, 2) the Fiberfrax crushes a little at the point of attachment, leaving very little thickness at the rivet lines and 3) the SS sheet would add a bit of tensile capacity to the bottom skin.
It would probably have been better to use separate/extra rivets to secure the SS sheet/FF to the belly (I thought of that for my firewall), but, for my small belly shield, I didn't do it that way.
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 03-12-2018, 08:08 PM
jeffwhip jeffwhip is offline
Do this ^^^^^
Dan,
Do you have any pictures of what that looks like?
Jeff
Rudder - Complete
Horizontal Stabilizer - Complete
Vertical Stabilizer - Complete
Elevators - In the Works!
Cabin Cover - Complete (wheewww!)
Dues Paid Through 2018
Old 03-12-2018, 10:19 PM
Originally Posted by jeffwhip View Post
Dan,
Jeff
Here you go (I think)...
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-17-2018, 05:33 PM
Thanks! That's what I'm looking for.
Rudder - Complete
Old 03-17-2018, 05:53 PM
Walt's Avatar
Walt Walt is online now
If it was me, I'd want to be sure the underlying skin was carefully prepared and corrosion proofed before riveting a plate on. Once you install it inspection will become impossible, and there is a good chances of moisture getting in between the 2 skins and with the dissimilar metals it could be a problem down the road. It would be more work but maybe worthwhile if you're building to use screw/nutplates to intall the sandwich.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 03-17-2018, 06:00 PM
Unless you start your -10 fuselage with this in mind, retrofitting nutplates under the floorboards will be a bear. That said, yes, do put a coat of epoxy or zinc chromate on the aluminum to protect it.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-18-2018, 09:46 AM
Weasel's Avatar
Weasel Weasel is offline
Default Another one
Dan,
Jeff
If I remember used 0.005" SS
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1500hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 03-18-2018, 01:27 PM
rdrcrmatt rdrcrmatt is offline
Stupid question, what's the purpose here?
I can only think it is to insulate from the heat of the exhaust.
Matt
2018 Dues Paid.
