Old 03-11-2018, 05:03 PM
AviatorJ AviatorJ is offline
Default Cowl fitting questions
Between my mods and bad trimming jobs I've been in sort of a cowling, baffles loop. I see the end so I'm looking at some of the things I pushed off. Any help would be appreciated.
Page 47-6 Step 13 talks about Beveling the eyelets along the curved portion of the Cowl Attach Hinges. The figure only shows 4 hinges to bevel, all at the top part of the curve. Are these the ones I should bevel or should I bevel the 15 or so eyelets along the entire curved area? Should note I can get the cowl on, just using takes a hit of my fist to go in... assuming that's what these are for.
Page 47-10 Step 1 is attaching the Support bracket on the bottom of the cowling to the bottom of the plane. The hardware it calls out if essentially a #8 machine screw and one of those tiny profile nuts. Is there some reason I can't use a nut plate for this? I can't really get my hand under the nose gear and inside the cowling to hold this tiny nut... makes sense to use a nutplate but wanted to ask.
Thanks!
Justin
RV-10 Quickbuild 'Final Assembly'
http://operationrv10.blogspot.com/
Donated for 2018
Old 03-11-2018, 05:45 PM
az_gila's Avatar
az_gila az_gila is online now
Thanks!
It's a one off installation so it shouldn't need a nutplate. Just get your pliers and small wrenches out.
It can be installed with the cowling off.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-11-2018, 05:53 PM
Oh, ha... okay now I feel silly. I was thinking you had to take it on and off when removing the cowl. I can get it on pretty easy with the lower cowl off.
Justin
Donated for 2018
Old 03-12-2018, 06:36 PM
Anyone help me with this?
Justin
Donated for 2018
Old 03-12-2018, 07:53 PM
You need to bevel the eyelets on the curved sections. Not on the straight segments.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-12-2018, 08:13 PM
Okay Iíll start with those first 5 or so and see how that works.
Justin
Donated for 2018
