Old 03-11-2018, 02:36 PM
bkervaski's Avatar
Default Alternator Belt Alignment
All,
Using the Plane Power alternator from Vans on an IO-390. My belt alignment is about 1/8 inch aft of the flywheel creating an angle and there doesn't appear to be a way to shim it into place, the bracket is non-adjustable.
Am I missing something?
Progress: Flying!
Old 03-11-2018, 04:22 PM
bluskydreamin bluskydreamin is offline
Default pretty common
At the Alternator to engine mount location....Remove some material from the alternator mount bushing and shim the alternator (use washer) in the direction you need for alignment.
Old 03-11-2018, 06:57 PM
Bootscooter's Avatar
Bootscooter Bootscooter is offline
I had this problem, turned out was simply the orientation of the bracket.
Study the Plsne Power install diagram very carefully will fit without shimming.
Chad Boot
RV8 Empennage in progress
RV14 140331 VH-VNX. Flying/Sold
RV10 Standard Fuselage Complete
RV10 Empennage complete
RV-7 Slider Flying VH-VNZ
Sports Aircraft Assn Australia. Tech Councillor.
2018 Dues Paid
