Old 03-11-2018, 09:49 AM
Stockmanreef Stockmanreef is offline
Default Empennage Fairing Installation Question
Maybe this is a dumb question, but I will ask anyway.
Section 11 is the attachment of the of the horizontal and vertical stabilizer, rudder and elevator.
Section 12 is the attachment of the fairings to the above parts. Should one put the tail together and put on the fairings to make sure everything lines up then take apart to do the fiberglass work? Or should all the parts be left in place.
Or do the parts need to be attached to the empennage to do the fairing attachment.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14 (serial number 140073)
N73XP (at least that # reserved now)
Old 03-11-2018, 10:06 AM
I would tell you that the HS and VS need to be attached to the fuselage to fit the fairing. I'd leave it all assembled until the fit/finish is complete for that fairing.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-11-2018, 11:13 AM
KeithB KeithB is offline
From a storage perspective, Id say its dependent on your shop and space. I have a larger shop, but after assembly including hardware, I took it all apart. The components were hung high on the walls out of harms way, but suitable for show-and-tell. On a practical basis, when the fuselage gets married to the empennage, tail fins would be in the way, and if you use a rotisserie (as I did), you need the rear surface where the vertical stab mounts for mounting. It was over 2 years before the VS & HS got reassembled again as part of final assembly.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, >300 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
