Old 03-12-2018, 05:27 AM
Bgill Bgill is online now
Small diameter “O” rings - (thicker ones) work very well. Most hardware stores carry as well.
Old 03-12-2018, 05:39 AM
salto salto is offline
I used the rubber washer off a tek screw
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 03-12-2018, 06:05 AM
I can see that washers would work well in some locations but I have built eleven aircraft without them. If the parts do not fit well together then perhaps you should adjust the flange or change the order of riveting. The parts, especially on the 14, should line up so that the use of rubber washers is not required
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 03-12-2018, 10:21 AM
DHeal DHeal is offline
I used @ 1/8" thick orange silicone baffling sheet cut into very small squares with an appropriately sized rivet hole punched in the middle -- worked great in compressing the aluminum parts together while squeezing or riveting.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 700+ hours (as of Nov 2018)!
VAF donation through June 2019.
sblack sblack is offline
I had a snag from the inspector on a gap between a stab rib and spar. Vans told me that the only purpose of that rivet was to hold the rib in place so that the skin could be riveted on. The loads go from the the skin into the spar. So that gap will not affect the structural strength of the tail. Of course you want to know how you can improve your workmanship, understandably, but don't waste your time drilling this out and risk elongating the hole etc.
Scott Black
RV 4, with an engine...and other stuff
VAF dues 2018
Old 03-12-2018, 01:03 PM
SabreFlyr SabreFlyr is offline
https://www.amazon.com/Ideal-Instrum...strating+rings
Perfect!
Ray Dosh
LJ45 driver
RV-14 QB #140212
VS, rudder & elevators finished
HS started
2018 DUES PAID
Marion, IN MZZ
Old 03-12-2018, 02:31 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Originally Posted by SabreFlyr View Post
The warning plainly says, "For Veterinary Use Only" so only Veterinarians can use these!
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
“Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
