Old 03-08-2018, 06:44 PM
PrescottB787 PrescottB787 is offline
Default Rev-10 Steps.
Looking ahead I was wondering about how the side skins lay against the 16 rivets that hold the step mounting brackets on. Doesn’t seem like it would lay to well around the step mounting bracket?
Old 03-08-2018, 07:40 PM
Jesse's Avatar
Jesse Jesse is offline
The -10 doesn’t have rivets that hold it in. It has blocks that mount to the ribs of the baggage floor.
352-427-0285
jesse@saintaviation.com
Old 03-08-2018, 07:59 PM
I was speaking of the step mounting bracket ( WD-1008-L). It riveted on with 4-4 rivets.
Old 03-08-2018, 08:11 PM
mciaglia mciaglia is offline
The rib that has the mounting bracket on is behind the skin. In the infamous chapter 29 you will bend the skins and they will not be in contact with the mounting bracket that is attached to the rib. I had the same concern, and that was alleviated after attaching the skins and seeing there is a space between them. Where in Houston are you? I am in the Woodlands, stop by and check the fuse out. I am getting ready to put the baggage floor panels in, so the area you are referring to will soon be closed up
Dr. Mark Ciaglia
Houston, TX
Donating Monthly since 10/17
N189PT- Christen Eagle II
N627DG (reserved)- RV10 in the making
www.marksfamilyrv10.wordpress.com
Old 03-08-2018, 08:37 PM
Just PM you Mark. Thanks
Ken
