Old 03-08-2018, 10:06 AM
KatanaPilot KatanaPilot is offline
Default Tip-up Canopy Lift Handle
I've searched but have unable to find what I'm looking for - a nicely made (read CNC) exterior handle for a tip up canopy.
The standard aluminum angle just doesn't do it for me as a permanent solution.
What I'm really looking for is a CNC machined piece, possibly in the shape of a Whitcomb airfoil with the reflexed trailing edge machined a little deeper for your fingers.
Anyone done this or have a good resource? If not, I'll have to draw it up and have Stein or someone machine it for me. It's times like this I wish I had gone to machinists school instead of the North Avenue Trade School
Krea Ellis
Locust Grove, GA
DA20-A1 Katana "Princess Amelia"
RV-7A Phase 1 under way, in paint at Evoke Aviation
RV-10 under construction
Old 03-08-2018, 10:20 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Canopy Handel
I have a nice solution to this if you are glueing your canopy. Can send you a photo on email. Please pm me if interested.
Al Girard, Newport, RI
N339AG
RV-9
Old 03-08-2018, 11:02 AM
Sam Buchanan's Avatar
been here awhile
I couldn't find a photo but I built the handle a little different from the plans and it looks more finished. The aluminum angle that is the handle is mounted inside the canopy skirt and only the 'handle' part of the angle protrudes past the outside of the skirt through a slit in the skirt. This leaves only the handle visible from the exterior of the airplane.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 03-08-2018, 11:23 AM
agirard7a's Avatar
Default Same
I did the exact same. I glued my canopy with Silka flex and used an
1/8 aluminum spacer between the side skin and frame. This allowed the required 1/8 gap for the glue. I cut a small area out of the spacer to receive the inside portion of the angle. Will try to post a pic when I can.
N339AG
RV-9
