Old 03-07-2018, 11:39 AM
RandyAB RandyAB is offline
Default Rudder bearing block placement.
I'm currently mounting the exquisite Control Approach pedals that Paul Grimstad sent this week. There is an extra hole in each longeron where the rudder bearing blocks attach resulting in two possible positions with respect to fore and aft placement. I'm not seeing in the plans an explicit statement that this is deliberate and for the builder to decide although I suspect perhaps it is. The plans show a more forward placement. Can somebody confirm for me that this is a builder's choice decision?
Good day to all.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 03-07-2018, 11:49 AM
Flandy10 Flandy10 is offline
The builder has the option of selecting either position for the rudder bearing block. Its your choice. If you're 6 ft or more, I'd definitely recommend the forward position.
Scott Flandermeyer
Rv-10 TDI #40816
Fayettevile, GA
2018 VAF Donation complete
Old 03-07-2018, 11:52 AM
Originally Posted by Flandy10 View Post
If you're 6 ft or more......
Lol. I wish.
Thanks Scott.
Randy P.
1st time builder
2017 dues paid
Old 03-07-2018, 02:16 PM
Default position
I am 6' and used the AFT set of holes...
Note that this will change the dimension on the rudder cable straps...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 03-07-2018, 02:56 PM
Ya, the plans mention that. I'm using Control Approach pedals so now I'm trying to determine if that changes anything since the cables don't exit the tunnel as per the stock setup.
Randy P.
1st time builder
2017 dues paid
