Old 03-06-2018, 07:03 PM
billieracing billieracing is offline
I completed my fuel flow calibrations, float level calibrations, and checked unusable fuel this past Saturday. Very happy with 26 GPH on the electric pump. 2oz of fuel left per tank or less, there was so little the pump could not pump its not even worth mentioning.
If anyone is a gallon or more of unusable fuel there is an issue, assuming the pickup tube is not on the bottom inside of the tank????
Billie Racing
RV-9A, started 2015, finished ?
The blood that squirts from your finger after you run a #40 drill bit into it is proof that your still alive.
Old 03-07-2018, 05:32 AM
bobnoffs bobnoffs is offline
it was earlier mentioned that weight measurement is the most accurate. that may be true but not helpful here. your system leaves fuel behind by volume, not weight.your unusable may be 6lbs on a cold day and 5lbs 14oz on a hot day.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12.
RV-12 kit as of 9/13
Old 03-07-2018, 08:33 AM
airguy's Avatar
airguy airguy is offline
Either way that's still too much - almost all RV's have an unusable in the 1-2 digit ounces (by weight OR volume) range. Gallons is not an acceptable unit of measure in this case, something else is hokey.
Greg Niehues - VAF 2018 dues paid
Garden City, TX
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 03-07-2018, 08:39 AM
219PB 219PB is offline
I agree with a previous post. I would not make the first flight until I fully understood the discrepancy. The downside is too great.
Paul Bonorden
RV-6A under construction
My Builders Website
Victoria, TX
2018 Dues Gladly Paid
Old 03-10-2018, 02:48 PM
KatanaPilot KatanaPilot is offline
Default Problem Solved
Today I pumped out all of the fuel using the electric fuel pump, then pulled the sump drains. Although the fuel remaining was not a couple of ounces, the total unusable fuel for my airplane with a flop tube is less than 0.25 gallons. While the right side pickup in the QB tank may be a little higher than desired, I find this result perfectly acceptable.
The problem clearly was twofold - the meter on the portable fuel tank was inaccurate and the "full" mark on the 5 gallon can I used to measure the fuel pumped out is also way off. So the fuel "in" and "out" were not measured properly. But the unusable fuel is within a reasonable range.
Krea Ellis
Locust Grove, GA
DA20-A1 Katana "Princess Amelia"
RV-7A Phase 2
RV-10 under construction
