Old 03-05-2018, 08:10 AM
Jimd Jimd is offline
Default Bow in Stiffeners?
Question about the RV-10 HS.
There is a moderate bow in the HS-1013, 1014, 1015 stiffeners due to the forming/punching process. These parts could probably be clecoed in place the way they are for match drilling, and even riveted. Or do most builders straighten them? For straightening, do you just lean on them or flute (these parts seem a bit to short in the leg and thick/heavy for fluting to work well). It seems like fluting could cause misalignment of the prepunched holes?
Sorry for the noob question, I'm new to this fancy prepunched world!
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Old 03-05-2018, 08:13 AM
RandyAB RandyAB is offline
I clecoed them in place and then match drilled. No problems. Use plenty of clamps while match drilling.
______________________
Randy P.
1st time builder
RV10 - Empennage (Started March 2017)
St. Albert, Alberta, Canada
2017 dues paid
Reserved:C-GRPY (GRumPY)
Old 03-05-2018, 08:55 AM
BrianDC's Avatar
BrianDC BrianDC is offline
Yep, did the same using lots of cleco clamps to hold the parts together. No issues.
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - in progress
RV10builder.com
Old 03-05-2018, 09:13 AM
ppilotmike's Avatar
Default Page 8-5, Step 2, Para 2, Sentence 2..
..says, "the spar cap (Ref. to HS-1013s) is somewhat bowed as supplied, so use plenty of clamps to make sure the spar cap is tight against the spar web and flange while drilling." I think this works because they are nested against the flange of the HS-1002.
However, don't feel silly asking this. You are right to question it, as there are some spots where Vans tell you to straighten things out, and others, where you are the judge/jury. For instance, my HS-1007 was bowed too. I straightened that out because it's supposed to be flat and this was an easy piece to get flat (i.e. no flanges on it). Consider what the part is doing, and whether or not it could possibly induce twist into the finished assembly. If so, straightening could be a good thing. Also, be sure to really de-burr those thick, punched parts well. KPTR!
Mike Rettig
EAA Chapter 301, President www.eaa301.org
VAF Dues Current: as of 01/15/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/mikrettig
Old 03-05-2018, 11:19 AM
Thanks guys! Helps me a bunch, especially the reference to the plans. I was about one paragraph from there when I decided to ask, while putting the tapper on each stiffener.
Jim
RV-6
RV-10 tail kit 50%
