Old 03-04-2018, 09:04 PM
asw20c asw20c is offline
Default Fuel Tanks
My next session in the shop will be the first time where I will be using the fuel tank sealant. I'm sure I would eventually work out a "system", but I thought I would solicit advice here first. I'm trying to envision what this will be like so I can anticipate how to set quality, non-leaking rivets while keeping up with the mess. So I have lots of questions. Just how much sealant do you put between mating parts? Run a bead down the middle and let it squish out? Completely butter the contact surface? Put sealant on both parts to be mated or just one of them? How do you apply sealant to the rivet? Just put a dab in the dimple? Put it on the rivet? What about backriveting? I plan to use backriveting for the stiffeners but I'm expecting that my backriveting steel plate is going to get covered in goo. Do you have to clean all surfaces after every rivet? Clean the bucking bar between rivets? How do you apply the sealant? Section 5 talks about putting it in a sandwich bag, cutting the corner off and using it like a chef. I'm guessing popsicle sticks might be helpful.
These may sound like naive questions but I'm terrified of having leaks at the end because I suspect fixing a leak will be much harder than doing it right the first time. Any advice from those who have gone before is much appreciated.
Empennage Complete Except for Tips
Wings Underway
Old 03-04-2018, 09:19 PM
Zuldarin's Avatar
Zuldarin Zuldarin is online now
Hi Clay, there are many ways to do this and many opinions. I just did a post last week on my build log that describes the technique I am using. Its just one of many but it works well enough for me.
http://www.darinanderson.com/2018/02...g-process.html
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Fuselage
www.DarinAnderson.com
2018 donation sent!
Old 03-04-2018, 09:50 PM
salto salto is offline
After making sure everything was ready I just buttered up all the ribs except the inboard one and carefully placed them in position. The proseal expressed itself after clecoing into the counter sunk topskin which I cleaned out with ear buds. It then took about an hour and a half to rivet all the ribs which was within the two hours available. Then did the inboard rib and drag link plus fuel cap receivers. Swirled a dollop of proseal on all rivet heads.
I copied a process mentioned in another post and taped the rear bulkhead in place and gently pressurised. Only had one leak up underneath the drag link fitting which was still easily accessible.
The rear bulkhead goes on real easy as instructed.
Then had a party with some balloons. 🎈
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
KeithB KeithB is offline
I found this thread to be one of the most informative, and it formed the basis for the process I used.
http://www.vansairforce.com/communit...ead.php?t=7602
The key to the "fay sealing" method described is to apply the pro seal, 100% cleco the parts and then let the pro seal set up before riveting - much less mess.
Also, rather than using bulk pro seal in a can, for the tanks I bought the caulking gun tubes (Aircraft Spruce http://www.aircraftspruce.com/catalog/appages/ps890.php P# 09-04643) - the entire tube is activated so its no good for small jobs, but outstanding for the work on fuel tanks if you plan your activities.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, >375 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
VA Maule VA Maule is offline
Default Pro seal
Go to VAF Forums page then down to RV building tips/techniques. The very first one tells all you need to know.
The Best Government is less Government
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage underway
Old 03-05-2018, 10:23 PM
caapt caapt is offline
Wear a long sleeve shirt. Expect to throw away your clothes after it's all done. You'll be amazed how many places it's spread too. If I did it over again I would cover interior skins. I think the instructions say one strip of tape on either side of the ribs. Check the bottom of your shoes, or better yet take them off before going in the house.
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Old 03-05-2018, 10:51 PM
kiljoy's Avatar
kiljoy kiljoy is offline
I found unfortunately that the trick to sealant is practice. It took me a while but one of the things I learned with my first tank is when sealing over rivet shop heads was to dab some sealant on top of the shop head then use a popsicle stick and swirl it both clockwise and counterclockwise around the shop head to make sure that the sealant has contact on all of the surfaces as well it being even distributed.
And IMHO don't be afraid to use too much. I use 1 quart per tank (which may seem excessive) but I've never had a leak wherever I've applied sealant. Besides a few extra pounds of seal is worth the peace of mind.
Dues paid (2019)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - Crating late Jan. 2019
YouTube Build Channel
Old 03-06-2018, 03:42 AM
Tom023 Tom023 is online now
Buy a used Semco sealant gun off eBay or The Yard Store for $45, easily one of the best tool purchases I made and used extensively on the fuselage as well. The one with the side paddle trigger allows easy access into tight areas. I Followed Vans instructions and riveted while the proseal is wet. I was amazed by the amount of proseal that squeezed out during riveting even after applying the specified amount and clecoing. You do have to deal with wet proseal on your riveting tools but an easy solution is to cut a few hundred 2" squares from those blue paper shop towels. A quick wipe on the bucking bar, rivet set or rivet and discard, makes quick work of any excess Proseal. Others have had good success using foam rollers to apply an even coat of proseal on the rib flanges as opposed to popsicle sticks.
RV14A #140083
Down to last 5%.
2017 Donation
Old 03-06-2018, 05:02 AM
I didn't have any success with a foam roller and used a two inch hard plastic printers roller. Worked a treat and is a fast way of applying the proseal.
Kit 140241
Tail Feathers done
Canopy next. Phew!
Old 03-11-2018, 06:47 PM
Default Update
Ok, so yesterday was my first time using the fuel tank sealant, and I have to say as much as I was dreading it, it was even worse than what I imagined. First, even though I spent a few hours thinking about what I would need to do and in what sequence so as to plan out all my movements, I still messed things up. I had planned to use my pneumatic squeezer to rivet the finger strainer flanges, but only when I had the goop on did I realize the yoke wouldn't fit and had to buck them instead. Messed up a few rivets and had to drill them out leaving shavings in the goop. Tried putting the 470-6-5 rivets in the tooling holes using my dimpling tool and only managed to lean them over. Mess everywhere despite going through about a hundred rubber gloves. I spent hours getting two flanges and one anti-rotation bracket riveted to a single rib. I'm disgusted with the outcome. It was a comedy of errors, nothing but problems, and frankly the worst build session I've had since starting the project. Just short of a disaster. Here it is more than 24 hours later and the goop still has not set up (although admittedly my shop is about 40 degrees inside). Not sure how I'm going to power through finishing the tanks now that I know how miserable it is working with fuel tank sealant, and how long it is going to take if I have to go in baby steps the whole way. This stinks.
Wings Underway
