Old 03-04-2018, 12:17 PM
amaris amaris is offline
Default Flap top skin question
I'm starting the assembly of the flaps and notice this gap where the top skin isn't tight with the rib. Anyone else? Does this go away as the final rivets pull the skin down tight? Seems like something is wrong. Both L & R have the same.
Thanks!
Allen
Allen Maris - 2018 Dues paid
Santa Ynez, CA
Old 03-07-2018, 12:58 PM
Raymo's Avatar
Raymo Raymo is offline
Take a look at drawing 14A and you'll see that the skin should lay flat in that area.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 03-07-2018, 04:05 PM
John Tierney John Tierney is offline
Check that the trailing edge is straight V-shape. Many year ago Van's had a run of flap skins that were not bent correctly after the pre-punch. (I had two of them). The incorrect bend caused a slight ski jump look to the trailing edge.
John Tierney
Salem, WI
RV-7A - Finish/FWF Kit
N70JT Reserved
Old 03-08-2018, 10:32 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I don't know if it is even possible due to skin hole spacing, but is it possible you have the L and R spars reversed? (and upside down).
Usually, if something is that far off, you have made a mistake.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 03-11-2018, 09:32 PM
I sent it to Van's to see. After double, triple checking, all parts were fine. Van's said to check the spar/rib line and make sure it was straight. The skin just had a little too much curl to it and was too strong for the clecos to hold it. The rivets pulled it tight and all is fine.
Santa Ynez, CA
