Old 03-02-2018, 06:59 PM
rolick22's Avatar
rolick22 rolick22 is offline
Default Riveting of the side skin to F-01204G-L
I'm trying to figure out why I am not supposed to rivet the upper portion of the side skin to F-01204G-L (side Bulkhead). (see RED) I don't see any reason not to, but I yield to the wisdom that is Van's until someone tells me otherwise. (See page 23iS/U-10)
_____________________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
iS Finishing Kit In work
iS Fuselage Kit In work
1st GEN FUSELAGE SOLD
Serial#12-0864
N864DR Reserved
Old 03-02-2018, 09:37 PM
rv9builder rv9builder is offline
Interesting observation, David. I studied page 23iS/U07 and 23iS/U10 and they donít seem to be saying the same thing. On page 10, it definitely looks like you shouldnít rivet those holes. However, on page 7, the holes that arenít supposed to be riveted are marked with a triangle, but the holes youíre asking about donít have a triangle.
Sounds like a good question for tech support. Please let us know what they say.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 03-03-2018, 05:57 PM
Jim T Jim T is offline
My guess is that it has something to do with the fuel tank install that comes later. My old style kit doesn't even have those holes.
Jim
RV-12 kit no.: 120647
Working on finish kit
http://www.mykitlog.com/JimT
2006 Rans S-6S Coyote (flying)
Old 03-03-2018, 09:01 PM
rolick22's Avatar
Jim
I have thought of that to, but the fuel tank does not attach to the holes or any kind if support structural that are associated with the open holes. The tank is supposed only by three attachment points using 3 bolts. I just think it’s a typo. I will find out more on Monday I hope.
David Rohrlick
PPSEL A&P
Serial#12-0864
N864DR Reserved
Old 03-04-2018, 04:05 AM
mike newall's Avatar
David/Doug,
Maybe time to split the forum or ask people to define whether it is a Mk1 RV12 or a Mk 2.
This is a Mk2 as we legacy builders have different structure around there.
Donated twice in 2017
Old 03-04-2018, 06:50 AM
rolick22's Avatar
Originally Posted by mike newall View Post
David/Doug,
I second that, there are enough differences in the structure, fuel system, electrical and engine to warrant another model. I like Mike's idea, "RV-12 Mk1" and "RV-12 Mk2". To confuse things even more the Mk2 (I guess for now it's the iS fuselage) fuselage is also available with the ULS engine option.
Mothership: "There's something very important I forgot to tell you."
VAF: "What?"
Mothership: "Don't cross the streams."
VAF: "Why?"
Mothership: "It would be bad."
VAF: "I'm fuzzy on the whole good/bad thing. What do you mean, "bad"?"
Mothership: "Try to imagine every RV-12's as you know it stopping instantaneously, and every molecule exploding at the speed of light."
David Rohrlick
PPSEL A&P
Serial#12-0864
N864DR Reserved
Old 03-04-2018, 10:38 AM
David/Doug,
Not a big deal either way, but Iíd leave all the RV-12s in the same forum. Looking at the entire airplane, not just the fuselage, there are a lot of parts in common between the two models. To me, having two different fuselages and two different engines isnít that different from other RV models that are available in taildragger and tri-gear configurations and can be powered by a wide variety of engines.
I definitely agree that you should say whether itís Gen 1 or Gen 2, but you can also tell if someone refers to a page in the plans.
For Gen 1, the pages are numbered by like this: Page 20-05.
For the iS fuselage, pages are typically labeled like this: Page 20iS/U-05.
Pages that are only for 912 iS-powered aircraft look like this: Page 27iS-05.
Pages that are only for 912 ULS-powered aircraft look like this: Page 27U-05.
RV-12iS Fuselage
RV-9A Project: Sold
Old 03-04-2018, 11:06 AM
Simply needs to be in the title.
The rest would be self explanatory
Love the GB ref - marvellous !
Just don't refer to the 12 as a dog though...... Zuul !
Old 03-05-2018, 04:30 PM
I have thought of that to, but the fuel tank does not attach to the holes or any kind if support structural that are associated with the open holes. The tank is supposed only by three attachment points using 3 bolts. I just think itís a typo. I will find out more on Monday I hope.
I'm surprised that the new transverse fuel tank in the IS fuselage only attaches with 3 bolts.
Jim
Old 03-05-2018, 05:24 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Well, I read somewhere that the space shuttle was attached to the 747 carrier aircraft with only 3 bolts...
Tony
RV-12 #202 -- Flying
