Old 02-28-2018, 10:03 PM
dannp dannp is offline
Default Access panels
I'm trying to find threads and/or links concerning access panel installations in the tunnel for the fuel pump and similarly for tire air stems through the wheel fairings.
Dan
Dan
RV 10 @ DVT
Old 02-28-2018, 11:16 PM
az_gila's Avatar
az_gila az_gila is online now
Dan
I just put one of these in... went in as advertised.
https://www.airward.com/products/rv-...tersunk-screws
They also sell just the reinforcing ring and you make the panel and buy the screws and nutplates.
The only scary bit was hacking into an existing good panel to make a big hole.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-01-2018, 06:05 AM
GregMac GregMac is offline
Default Access Panels
If youíve got the standard Vans panel & throttle/mixture/prop bracket something you may consider is cutting the top of the tunnel so as to access the fuel pump/filter etc. As others have done I cut the the top at about the third screw back from the firewall and at the fuel selector. By riveting flat ally and nut plates to the pieces that donít have to be removed and three or four screws through the top, the panel is easily removed and the overall structure/strength is retained. Leaving that piece in the front is a real time/angst saver when it comes to service time. A quick way to have easy access to tire valves is to holesaw round holes of inch & quarter, inch & half or two inch holes (whatever you think will give easy access) in the appropriate position and fill the holes with rubber plugs, the sort you find as plugs in your car, those plugs are easily removed but are snug in service, the sort that have a lip on both sides are the best. Cheers from Western Australia
