Old 02-28-2018, 07:20 AM
Geico266's Avatar
Geico266 Geico266 is offline
Default Replacing The Windscreen
Has anyone replaced a windscreen?
I have crazing in my windscreen and Iím looking for advice and options to replace it. I noticed some builders have used aluminum fairings, but that was on a 7. Since the cabin is fiberglass Iím assuming that wouldnít be a good idea? Thoughts? Or just dig out the old one and refiberglass and paint?
As always any thoughts or suggestions greatly appreciated. Thank you in advance.
RV-7 : In the hangar Thank You Marco & Jenny
RV-10 : In the hangar
RV-12 : Built and sold
RV-44 : 4 place helicopter on order.
Old 02-28-2018, 07:38 AM
mturnerb mturnerb is offline
Vic Syracuse just did this on his RV-10: if he doesn't come along soon, reach out!
(FYI he looked great covered in plexiglass dust when we did a Facetime session!)
Turner Billingsley
RV-14A In Progress
N14VB Reserved
Old 02-28-2018, 10:56 AM
Default Windscreen
I haven't installed it yet but I purchased the aluminum fairing from ML Skunkworks...
On another note, I went with the Cee Bailey windows and windscreen.
I have a stock Van's windscreen that I will not be using and will make a deal on if you want it...
Let me know!
Bob
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 02-28-2018, 12:57 PM
Dustyone Dustyone is offline
Default Router with dust extraction is your friend
I did this last year for a customer.
A router with dust extraction made this a straight forward job.
The Cee Baileys windscreen was a great drop in replacement with hardly no trimming required and that annoying bulge in the lower r/h corner like the Vans screen has,was not there.
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 500hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 02-28-2018, 01:02 PM
Super Moderator
Yes, I just did mine, and used a router for the top cut and a cutoff wheel for the front. Interesting that i used the Cee Bailey windscreen and mine had the annoying bump on the lower right side. I didn't think that was supposed to be there.
I used Sika flex to reinstall rather than the weldon. It was less messy and longer working time.
Vic
Vic Syracuse
Van's East Coast Representative
www.Baselegaviation.com
Old 02-28-2018, 02:30 PM
Geico266's Avatar
Vic
Cee Bailey advertises them without the bump.
Over all was it a good upgrade for a replacement?
No trimming?
Thanks Vic!
Old 02-28-2018, 03:26 PM
Auburntsts's Avatar
What are the techniques for separating what's left after the rough cut from the glue joint? Also are the techniques adhesive dependent (Sika vs weld-on vs Lord)?
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 02-28-2018, 05:33 PM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Wind shield?
What is the reason that you guys are replacing your windshields? Mine is 8 years and 1000+ of flight hrs. old and still looks nice and clear. It scares to think that I should have to replace it in the future.
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV)
1140 hours.
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 02-28-2018, 08:28 PM
Geico266's Avatar
Crazing from previous owner using the wrong cleaner I presume.
Vic? Flying too much, wore it out.
Old 02-28-2018, 08:49 PM
Super Moderator
I don't know why mine crazed. It got really bad. The interesting thing is that there is another RV-10 on the field that is the same vintage (2009) and it's windshield is crazing with the same pattern.
Why did I replace it? Carol said she wouldn't go to Alaska with me this summer unless I replaced it. Too much beautiful scenery to miss.
Vic
Vic Syracuse
