Old 02-27-2018, 02:42 PM
juliospain juliospain is offline
Default sliding canopy
Hello partners:
Can anyone inform me if you I can fly the RV9/A with two inches open the slidind canopy ?
greetings from Spain
Julio Bueno
Old 02-27-2018, 02:44 PM
airguy's Avatar
airguy airguy is offline
Several pilots have flown the airplane with the canopy cracked open an inch or two, usually accidentally or during test phase. I did it during test phase with it open 1" with no problems except the obvious wind noise and breeze.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2018 dues paid
N16GN flying! http://websites.expercraft.com/airguy/
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-27-2018, 02:51 PM
fl-mike's Avatar
fl-mike fl-mike is offline
As Greg said, usually not on purpose!
There is substantial "lift" on the canopy in flight.
Take a look at that plastic slider block on the track and ask yourself if that is all you want holding the $1000 canopy on the plane (as opposed to the dagger pins holding it on in the closed position).
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 02-27-2018, 09:53 PM
airguy's Avatar
Right. I can attest that in an RV9A with no flaps and holding 60 knots, it was not possible for an otherwise-healthy adult male in the right seat to move the slider canopy with it cracked 1" open.
We won't discuss why or how we came to that observation, only the results of it. Suffice it to say that I cast serious doubt upon the possibility of opening the slider canopy for bailing out of a wounded airplane. My next airplane will be a tipper or flopper.
Old 02-27-2018, 10:52 PM
Jermechanic's Avatar
Jermechanic Jermechanic is offline
Default EAA story
There was a story in the EAA magazine a while ago about an RV6 who had removed his canopy and closed in the baggage compartment slightly to fly slow locally with the wind in the cockpit. Cool story! I have trouble slowing unless Iam landing; i have a bit of a speed addiction
Jeremy Prpich
C-GJZI RV6 Slider
Home base CYYJ- Victoria Int'l
Old 02-28-2018, 09:22 AM
vlittle's Avatar
vlittle vlittle is offline
There is a video of an RV performing a forced landing in the water near a beach after a mid-air collision. The pilot had slid open his canopy before touchdown. https://m.youtube.com/watch?v=Sy_IkRR4xOk
So that is documented evidence that it can be done.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 02-28-2018, 10:24 AM
airguy's Avatar
Agreed - at least one documented evidence that it can be done - but I also noticed that the canopy slammed shut on him during the landing sequence (you can see it from the second camera angle) so in that particular instance the value of opening the canopy was questionable - but yes, at least one person was able to open it.
Old 02-28-2018, 12:23 PM
flyboy1963's Avatar
Default forensic study time....
I had NOT seen that video, thanks for posting.
from a purely educational standpoint, what can we learn?
1. the canopy, unless pinned open somehow, will slam forward during most impacts, water or land. I see headset removal at the very least!
2. would it be preferable to be conscious, without the 60 kt water enema that results upon impact?...and then deal with opening the canopy while inverted? could give you precious seconds of NOT inhaling water.
3. what the heck shoots vertically out of the cabin at 0:21?, and is then swatted forward by the tail? oh, perhaps second angle shows.... it's the wheelpant jettison function?!?
....regardless, kudos to the pilot for landing right beside rescuers and an ambulance. ( obviously pre-arranged!) hope he/she was ok.
Perry Y.
RV-9a - SOLD!....
kinda missing it!
Lake Country, BC
....paid up til Nov. 2018
Old 02-28-2018, 01:03 PM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Would it be even possible to open a slider canopy while inverted in water? Takes a pretty good tug in air... Remember it has to lift to open - against ? water pressure...
I have pip pins on the front mounts of the canopy on the -8. I have already made the decision that if I have to ditch, the canopy goes before hitting the water. Yes it would be a slap in the head. Yes it might damage the vertical stabilizer...
I am more comfortable with the thought of this than the thought of being inverted without air in a slowly sinking airplane and not being able to open the canopy...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 25, 2018
Old 02-28-2018, 03:04 PM
If you've got a pax and you know you're in for a water landing, hand him or her the Life Hammer and start breaking that sucker into little pieces!!!
Doug
RV-9A "slider"
Flew to Osh in 2017 & 2018!
Tail number N427DK
Donation made for 2018
