Old 02-26-2018, 12:00 PM
Tiger28760 Tiger28760 is offline
Default Rudder Trailing Edge Wedge
How did you drill the #40 holes perpendicular to the cord of the wedge?
Old 02-26-2018, 12:28 PM
control control is offline
cant remember, I probably did that one on free hand letting the drill follow the holes in the VA-140.
For some other edges I made a wooden block with an angle that would make the drill go 90 degrees to the cord.
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 02-26-2018, 12:37 PM
azflyer21 azflyer21 is offline
I used the extra length that was cut off and reversed it putting the two pieces together so it created a flat surface.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N902X reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 02-26-2018, 12:45 PM
MED MED is offline
Cleaveland Tool makes a nice tool to make this job easy. About $25, I believe.
MED
140236
N435MD reserved
Old 02-26-2018, 12:46 PM
If you reference to the surface of the extra wedge, you would not be drilling perpendicular to the center line of the trailing edge wedge. You would be drilling perpendicular to the opposite side of the trailing edge wedge.
Scott McDaniels
Hubbard, Oregon
Old 02-26-2018, 01:02 PM
Mudfly Mudfly is offline
EDIT I misread the original post. As Scott explains below, the tool I list in the link should only be used when countersinking the holes of the trailing edge and not for final drilling the #40 holes perpendicular to the chord line. Sorry for the misinformation.
http://www.cleavelandtool.com/Drill-.../#.WpRnhWinHrc
Shawn Edwards
RV-14A (140174)
Empennage purchased (pre-owned) August 2015
www.myrv14build.blogspot.com
Old 02-26-2018, 01:23 PM
Originally Posted by Mudfly View Post
I didn't even know Mike was selling this tool, but it is not made in a way that it should be used to final drill the wedge. Only for doing the machine countersinking.
The desire is for the holes to be final drilled perpendicular to the cord center line. Not one of the sides
This tool is aligning the side of the wedge square to the chuck (if used in a drill press), so it is fine to use in place of the simple method described in Section 5 of the construction manual, for doing the machine countersinking of the wedge, but not for final drilling.
Scott McDaniels
Hubbard, Oregon
Old 02-26-2018, 01:44 PM
Bavafa Bavafa is offline
I used a wooden block cut to the angle that would make the drilling 90 to the cord and the back side of the block is set for flush for the counter sinking which needs to be 90 to the surface and not the cord. I have no use for it anymore and if you were nearby, I could just send it out to you.
I may have the measurements (angle) for the cut and will look it up tonight.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 02-26-2018, 02:19 PM
dejavu dejavu is offline
As azflyer21 hinted, I used the extra cut-off wedge as a guide clamped to the drill press. The aft (pointed end) of the TE wedge inserted into the fwd of the cut-off wedge should get you close to the chord line for drilling.
When counter sinking, as azflyer21 & Scott mentioned, I reversed the extra cut-off wedge placed under the TE wedge should provides a perpendicular to the TE wedge surface.
-Tom
Grateful & happily donated 2018
Mooney M20-F
RV-14A Empennage
QB Wings & Fuse
Old 02-26-2018, 02:35 PM
This template is cut to the angle specified in section 5.
Thank you
John S
Fuselage started
