Old 02-26-2018, 11:34 AM
bkervaski's Avatar
Default Canopy "D" Seal Issue
Well, that's an issue. Any thoughts? Just need to get a fresh one and try to get it positioned further aft?
Basically, I guess it can't really be installed in a straight line, I'll have to curve it around the canopy skin relief.
Progress: Away for PAINT
Old 02-26-2018, 12:22 PM
control control is online now
Not good enough is my take on it.
I messed up my supplied D-seal and had to find replacements. My local store (in Sweden) had something that is probably the same brand and about 80% of the size from what Vans supplies, check your local store that carries seals for windows, boats and things like that. With some luck you should find something slightly smaller that will fit.
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 02-26-2018, 12:38 PM
Yup.
And Yup
Scott McDaniels
Hubbard, Oregon
Old 02-26-2018, 03:00 PM
bkervaski's Avatar
Thanks guys! I ordered a couple, round 2!
Old 02-26-2018, 07:59 PM
n982sx n982sx is offline
I had the same issue.
As it turns out, i must of gotten lucky when Van's sent me the original material. I was going to order more but I decided to see just how much was left over from the original shipment. Turns out it was just enough to redo by a quarter inch.
I only had to move it back in the flat middle section. Each curved side fit fine.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 02-27-2018, 09:58 AM
bkervaski's Avatar
Okay, got it, third time's a charm! My "D" seal on the canopy relief needs about 1/8 clearance at least to prevent the squishing toothpaste effect.
Old 02-28-2018, 09:00 PM
Logan Logan is offline
I had same thing first time I closed the canopy after placing that seal. I tried tucking it in as I was closing the canopy, had a friend with a plastic squeegee-type thing push it an as we closed canopy. After sitting closed for a while, It seems to remain where it needs to now. Will keep an eye on it, but it seems to work fine for now.
Logan Dent
RV-14A Complete!
Airworthiness cert issued June 27, 2018
