Old 02-27-2018, 01:30 PM
RV7ForMe RV7ForMe is offline
Originally Posted by CubedRoot View Post
However, the flaps and ailerons.... no issues with building them before jigging the wings.
Sweet. So I will check back with you in a little bit when you are further along and ask about the tanks. Thanks
VAF dues paid until 05/2018
RV7 - Empennage 95% done
RV7 - Wings Started...
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 02-27-2018, 04:59 PM
wirejock's Avatar
wirejock wirejock is offline
Default Tanks
I wouldn't build tanks without wings. Very tricky to get the z-brackets and rear baffle drilled perfectly without the wing. Just my $.02
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-28-2018, 05:34 PM
jcarne's Avatar
jcarne jcarne is online now
I agree with larry, in my mind building the tanks with the wings assembled is a must.
Jereme Carne
PPL
RV-7A Emp. done
Wings mostly done
Working on Fuselage
Finish kit on order
Exempt but gladly paying!
Old 03-01-2018, 11:28 AM
N329JR's Avatar
N329JR N329JR is offline
I believe that you will find that you really want / need the wings jigged up and completed to the point of tank baffle - rib - skin - Z bracket fitting on the spars and outboard leading edges in order to achieve the desired results for Z-bracket layout, alignment and drilling. My $0.015
I do appreciate your desire to conserve work-space. I am building in a compact single car garage sized space (because it is just on the other side of the wall from my living room) and keeps me within EASY reach of my project!
Good Luck and keep pounding those rivets as we say.
RV-3B My RV
RV-6 (Dad's RV)
RV-8 Empennage 95%, Wings 90%, Fuse 1%
2018 VAF Gladly Paid
