Old 02-25-2018, 01:36 PM
bsacks05's Avatar
bsacks05 bsacks05 is offline
My brushed on Randolph Wing Walk compound has been in place and giving traction for 12 years and 1100 hrs. The black faded a little and I repainted it a few years ago but the grip has been fine. No peeling or chipping either.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 02-25-2018, 06:12 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
https://www.aircraftspruce.com/catal...p?recfer=24992
Jerry Esquenazi
RV-8 N84JE
Old 02-25-2018, 07:08 PM
Originally Posted by RV8Squaz View Post
How does it do when it is wet?
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-25-2018, 07:48 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Originally Posted by Mark Dickens View Post
I remember that some have used skate board grip tape as a wing walk material. I will be taking my -8 to paint in about a month and am thinking about what I'm going to use after that. Wondering if anyone had a pirep on using skate board material?
Edit: and it's a lot cheaper too
$5 a piece (side) on the web.
Six years or so and no issues. Did have one of the little pieces on the step start to lift, so replaced that when I did the step reinforcement. Gnarly dude!
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 02-25-2018, 08:24 PM
RV8Squaz's Avatar
It works great Kyle. Iíve never had any issues with it.
Jerry Esquenazi
RV-8 N84JE
Old 02-26-2018, 03:29 AM
rleffler's Avatar
rleffler rleffler is offline
I had the material from Flyboys on my RV-10. On several occasions, I lost portions of the material in flight. They were gracious to offer replacements, but after the third time replacing them I gave up. They did give me a refund.
The issue was that the adhesive failed. What made it worse, was the failure was between the wing walk material and the adhesive. The adhesive was still firmly attached to the surface which was a pita to remove.
I was told that the primary intention for their product was from the marine industry. I did notice an issue while flying Young Eagles last summer that the adhesive would start to loosen in direct sunlight in the mid 70ís. While kneeling to assist kids with their seatbelts I notice that if I pivoted my knee the material turned too.
Iíve purchased the Ray Allen material which is a little more expensive, but I havenít put it on yet. Iím waiting for the hangar to be a tad bit warmer.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-26-2018, 06:21 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
The Vans stuff works great and after 6 years and 800 hours still looks new
Bill Peyton
RV-10 - 780 Hrs
First Flight Oct 2012
WA0SYV
Aviation Partners, LLC
Mudfly Mudfly is offline
Probably waaay overkill here, but just a thought. I'm not close to needing wing walk material, but have had this idea since I've been working on my wings. I had a truck bed with this product for years and it was very durable provided good traction even when wet. This product is different than some other bed liner sprays that are thicker and feel more "cushioned". Line-X appears to be a fairly thin layer, and can be textured as required. Options for durability, UV protection, and color are also available.
Not sure if mobile service is available so that would be an issue for a completed plane. I thought if I paint before flight this may be an option. One obvious disadvantage may be that once applied, it may be very difficult to remove if required.
Like I said, probably too involved for a wing walk material, but might be interesting for someone to consider...and let me know how it turns out
http://www.linex.com/bedliners
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
Old 02-26-2018, 08:08 AM
az_gila's Avatar
az_gila az_gila is offline
Question
Isn't Vans wing walk the same as the Ray Allen part?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-26-2018, 01:11 PM
Daida Daida is offline
Default +1 for Skateboard grip tape
It is cheap,
It works,
Comes in literally million different colours,
Comes in different grits,
It is all you need.
RV-8 QB Germany
metal work complete
ECi XIO-360 installed
Dynon SV
Wings+Empenage+Fuselage=Plane
Working on glass-thingies
Almost there!
