Old 02-24-2018, 10:22 PM
thoma015 thoma015 is offline
Default Spar damage
I purchased a partially built wing kit a while back and I'm to the point of mounting the leading edge and fuel tank when I saw a couple of nicks.
Is this something I can file down and prime?
Old 02-24-2018, 10:39 PM
mfleming's Avatar
mfleming mfleming is offline
No photo showing
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Empennage (sans fiberglass)
Ailerons and flaps complete.
Wings done (sans fiberglass)
Started on QB fuselage
Donated 2017
Old 02-25-2018, 08:00 AM
I guess you have to pay to use Photobucket now... It showed up fine when I did the preview. Anyway I'll try to share it in my Google photos.
Old 02-25-2018, 08:34 AM
jcarne's Avatar
jcarne jcarne is offline
I'm sure those are fixable, however, anything to do with the spars it would probably be a good idea to send an email to Van's. Especially on the main bars.
Jereme Carne
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 02-25-2018, 09:12 AM
acam37's Avatar
acam37 acam37 is offline
That looks like they used a screw that was too long for the nut plates.
Arlie Conner
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) under construction
KOCH Nacogdoches
Old 02-25-2018, 09:21 AM
Frank Smidler Frank Smidler is offline
Default Deffinately fixable
The spar flange loads lessen as you go out on the spar that is why you can taper them. To make it easier to mill and set the rivets the spars are stepped on the 7. Therefore to sand off a small amount of material to eliminate the nicks still will leave much more material in the area shown than if the flange was an actual full taper instead of a step. I'm sure Van's will tell you the same.
Frank Smidler
N96FS, RV-6, 2WI6
Flying 1/11/09
760 hr
Stoughton, WI
Formally of Lafayette, IN
Old 02-25-2018, 09:16 PM
longranger's Avatar
longranger longranger is offline
I damaged mine in a similar way when final drilling the tank skin to the baffle on my keft wing. A drill stop set very short would have prevented it. I sent photos to Vanís and they told me how to fix it.
Check out this entry and the next in my build log. Your damage looks a little worse than mine, so send photos to Vans tech support and ask them about it.
Miles (VAF# 1238, Paid up as of 12/2016)
RV-7 TU 904KM (reserved)
Wings Structurally Complete!!
SB Fuselage Just Past QB Stage
Construction Log
Picasa: Empennage Album, Wings Album, Fuselage Album
1955 Cessna 170B flying since 1982
'To get something you never had, you have to do something you never did.' -Unk.
