Old 02-23-2018, 09:04 PM
caapt caapt is offline
Default How do you make avionics box/brackets
Just received my avionics package. The mass of wires and connectors is a little overwhelming. I need a some plans or lesson on manufacturing a bracket or box to hold avionics in the open glove box hole. I have a picture example but plans would help.
14A Wing Complete!
Tail Complete
Fuse Complete
Engine installed
Old 02-24-2018, 05:16 AM
JDA_BTR JDA_BTR is offline
I did this:
http://www.vansairforce.com/communit...&highlight=MAP
N1463 seems a good number....
Old 02-24-2018, 07:29 AM
sahrens's Avatar
sahrens sahrens is offline
Someone posted an idea of using T-channel that captures nuts for mounting the radios. I can't find that original post. It allows the radios to be re-positioned easily without having to drill new screw holes; just loosen the screw and slide the radio and tray up or down.
Here is how I implemented his idea.
Installing the channel
http://www.mykitlog.com/users/displa...=222457&row=33
http://www.mykitlog.com/users/displa...=231424&row=11
Radio trays in place
http://www.mykitlog.com/users/displa...g=240176&row=7
Just one of many ways to mount the radios.
Scott
RV-7 N818BG
Old 02-24-2018, 08:52 AM
KeithB KeithB is offline
I covered over the map box hole with a plate and built rails between the panel and sub panel for mounting boxes.
http://www.vansairforce.com/communit...7&postcount=20
The pilot side has a GTR 20 radio, the co-pilot side has the GTX 23ES transponder with the GDL 39R ADS-B piggybacked. (The case for the transponder has to be removed from its mount before the transponder can be slid out of the case.)
I used the sub panel to mount the GAD 29, GEA 24 and a TCW IPS.
Keith Brown
RV-14A Builder - kit #136
N314KC - First flight Mar 8, 2017, >300 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 11/2017
Old 02-24-2018, 09:13 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Don't forget that almost all of the avionics installation manuals require some sort of rear brace to the avionics trays.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
