Old 02-22-2018, 05:21 PM
DeltaVee47 DeltaVee47 is offline
Default Toe in
Hi all
Just finished installing main gear. Very challenging for one guy but got it done.
However after installing the U00009 main gear axles I did the string test per the plans and Iíve got a ďyĒ measurement of 15 mm or 8 degrees of toe in on both sides. This seems huge since the plans say no more than .25 degrees is acceptable. I donít see how shims of .75degrees are going to fix this.
Guess Iíll call Vans tomorrow but feeling very discouraged right now.
Any ideas very much appreciated.
Thanks for listening
Greg Beckner
140-366
Old 02-22-2018, 08:56 PM
14a
Cannot see what I did wrong as everything lines up on the inside and both gears are toed in exactly the same amount. 8.2 degrees from horizontal.
Greg
Old 02-22-2018, 11:44 PM
n982sx n982sx is offline
Wow, that is way off. Do you have a picture? Maybe someone will spot something.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 02-23-2018, 01:35 AM
Originally Posted by DeltaVee47 View Post
14a
Greg
Horizontal?
Now you've confused me. The axles are almost certain to be angled down substantially with no load. That would be considered camber. If they are angled forward, that would be toe-in. A picture would clear up the confusion.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 02-23-2018, 06:04 AM
Default Duh
Kyle
You have cleared my confusion. A million thanks. I was looking from the front and confusing toe down with toe in. What a dumb mistake. So the gear is supposed to hang slightly toe down? Good, thatís what Iíve got. From above its perfectly aligned, no toe in. As usual, itís right there in the manual and I just missed it. Sorry to waste anyoneís time.
Yíall are the best.
Greg Beckner
Old 02-23-2018, 07:10 AM
Mel's Avatar
Mel Mel is offline
14a
Greg
From your description, it sounds like you are talking about "camber" and not "toe-in". That would also explain the amount. 8į would seem normal for camber. Toe-in is the deviation of track from straight ahead.
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 02-24-2018, 06:06 AM
jliltd jliltd is offline
Yup. Terminology matters. There is no "toe down". Toe in or toe out is strictly the view looking down or up at the axle from a level plane. So toe in is a condition where the front of the wheels are closer to the centerline of the aircraft than the back of the wheels. Toe out is just the opposite. It's like looking down at your feet while standing. If your big toes angle in toward each other that is toe in (analogous to pigeon toed individual). If your big toes angle away from each other that is toe out. If your feet are perfectly parallel that is zero toe angle.
Camber (which is what I think you are calling "toe down"?) refers to the bowleggedness of your main landing gear when looking from in front of or behind the aircraft. Like the stereotypical horse riding cowboy, positive camber angle results in the outboard tread of the tires contacting the ground first. Then as weight is added and the gear flexes the camber angle reduces and the geometry allows the balance of the tread to contact the ground. This is why most aircraft show more wear on the outboard edges of the main gear tires and why people sometimes dismount, flip and remount their tires to even the wear and extend the life of the tires.
Here is a link to a good reference...
http://en.intraxracing.nl/techniek/c...toe-intoe-out/
RV-8
RV-3B
Old 02-24-2018, 04:32 PM
Yes, lesson learned.
Thanks everyone
Greg Beckner
140-366
