Old 02-20-2018, 10:31 AM
JBHansen JBHansen is offline
Default Skyview Problem
In the process of installing dual Dkyview HDX. I am getting a message 'Skyview Network Connection Fault - Data 2 Pair (Pins 4 & 8)'. At the same time, Skyview is not detecting my two AP servos nor the Adahrs. Any ideas would help.
Old 02-20-2018, 11:39 AM
Raymo's Avatar
Raymo Raymo is online now
You'll want to ring out your serial/network cables for proper continuity and make sure you don't have recessed pins in any connectors. If both screens are showing the same error, look for a common connection to start troubleshooting.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 02-20-2018, 08:18 PM
Jesse's Avatar
Jesse Jesse is offline
I have seen this problem with a bad auto pilot servo, but usually it is a network cable that is not working correctly. Go into the settings and then to network status and see what devices are showing the fault. This should help you figure out where the problem is.
352-427-0285
jesse@saintaviation.com
Old 02-20-2018, 08:20 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Had same issue
Start here. Check the pin locations in the AHARs. I had them wrong. Once put in the correct locations all three will be detected if the rest of the wiring is correct. Canít for the life of me figure out why I had them in the wrong locations, but I did.
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
[COLOR="rgb(46, 139, 87)"]=VAF= Paid up 2018[/color]
Old 02-22-2018, 04:15 PM
I would like to thank the persons who replied to my post. It did turn out that the adahrs was wired incorrectly. It is now up and looking very happy Now on to the ap servos that have not been detected either.
Thanks again.
Old 02-23-2018, 06:30 AM
Jpm757 Jpm757 is offline
If the network does not recognize the autopilot servos then there may be a problem with the servo wiring. Pin out both harnesses for correct wiring. The autopilot calibration and servo test function will not be enabled unless BOTH SERVOS are recognized. I had this problem, and it turned out to be a faulty (new) pitch servo. Dynon happily replaced the servo and I was back in business.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 100+hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
2018 dues paid.
Old 02-23-2018, 08:41 AM
Raymo's Avatar
Thanks again.
JB,
Confirm you have provided 12v to the AP servos from your main bus. They cannot be powered by the serial network, as are the AHRS.
Ray
NSDQ
Old 02-23-2018, 10:51 AM
alexe alexe is offline
And confirm that the A/P switch on the panel is on :-)
Alex Erdelyi
RV-12 #120758, N912AE
Flying as of 4/28/15
Paid through December, 2018
Old 02-23-2018, 12:06 PM
Plus one for this^^^^
It has been the cause of quite a few AP system config. problems.
Scott McDaniels
Hubbard, Oregon
Old 03-12-2018, 01:59 PM
I have verfied 12v to the servos using the Vans wiring harnesses. They are stilool not showing in the Skyview Network Setup.
