Old 02-20-2018, 08:21 AM
Originally Posted by BobTurner View Post
I had a nearby construction equipment rental place that rented me a tilt-bed truck.
Yep, me too.
Old 02-20-2018, 10:57 AM
upperdeck upperdeck is offline
I used a flatbed tow truck for my 7. They were pretty excited to help, charged me $100.
Old 02-20-2018, 10:04 PM
joe_rainbolt's Avatar
joe_rainbolt joe_rainbolt is offline
Default delivered
5 miles, 30 minutes, no hassle, $125. Delivered into my hangar.
Joe Rainbolt
RV-7A slow build complete 4 July 2016
Flying
Blog: www.roughandreadyaerospace.blogspot.com
Old 02-21-2018, 06:04 AM
Jpm757 Jpm757 is offline
Flatbed is the way to go, but leave the horiz. stab OFF.
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 150+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub
2018 dues paid.
Old 02-21-2018, 05:54 PM
Kupde Kupde is offline
Thank you all for the many suggestions. Now it looks like I have a few different options.
Old 03-04-2018, 03:36 PM
Freightdawg's Avatar
Freightdawg Freightdawg is offline
If I may be so bold as to hijack this thread, I think all the photos I've seen of the move to the airport have been of aircraft already on gear. Anyone ever move the plane from garage to hangar before putting it on gear?
Jeff Rich
RV-10 Kind of all over the place in the plans. Need to get out to the airport.
N313KC reserved
In the garage for now, KJVY this summer...this fall...whenever they finish building the hangar
Old 03-04-2018, 03:57 PM
I moved mine several times with the gear off and on. I believe it is quite a bit easier off the gear than on. I built a 4'x5' platform for the fuselage to sit on to move around in my garage. I used a piece of plywood to roll the fuselage onto the trailer and then off. It worked fine. It is much easier to work on the fuselage off the gear and if I were to build again, the gear may be one of the last things to install!
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 03-04-2018, 07:11 PM
63robskin 63robskin is offline
I just purchased a RV10 project on the gear. Hired an aircraft recovery company to move it. They normally moved crashed planes. They lifted it onto a trailer with a set of Gin poles and a winch. They had a bar that was wider than the fuse and they dropped straps down each side to the spar. Took a small amount of balancing (pitch). It worked great. Everything else was inside a trailer. You might see if there is a recovery co. in your area.
Old 03-04-2018, 07:24 PM
Thanks.
(Here are my additional characters to make it a suitable length)
Jeff Rich
N313KC reserved
