Old 02-18-2018, 06:47 PM
Default RV-12iS forward lower fuse mating problem
I wonder if there are supposed to be two more slots on the forward end of the mid fuselage skin.
Here's why.
When you make the lower forward fuselage, there are two large -- for want of a better word -- ribs that rivet to the bottom skin and the firewall; these also hold a engine mount bracket/gusset.
You don't rivet the most aft hole on each, though, because those are common to the mid-fuselage skin too.
There are also two outboard stringers (again, for want of a better word, the RV-12 doesn't use part names, only part numbers) that do the same thing, but there are two slots in the skin to accommodate them. Not so for the inboard pieces.
The flanges on all four of these pieces are attach points to the a bulkhead.
Bob Collins
St. Paul, MN.
Almost ready to start the RV-12iS finishing kit. 480 hours in.
Builder log
Old 02-18-2018, 07:06 PM
rolick22's Avatar
rolick22 rolick22 is offline
Default Two more slots?
Here's why.
Hope this will help but I might not be understand your issue. The ribs over lap the two skins.
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished (need to add the panel cut out)
Wings finished (need to add the left landing light)
iS Finishing Kit In work
iS Fuselage Finished
1st GEN FUSELAGE SOLD
Serial#12-0864
N864DR Reserved
Old 02-18-2018, 08:07 PM
I'll do some more beating on it.
Bob Collins
St. Paul, MN.
Builder log
Old 02-18-2018, 08:43 PM
Jim T Jim T is offline
What step are you working on Bob?
RV-12 kit no.: 120647
Working on finish kit
http://www.mykitlog.com/JimT
2006 Rans S-6S Coyote (flying)
Old 02-18-2018, 09:38 PM
rolick22's Avatar
Here's why.
Make sure this rivet (IN RED) is not installed, will make it easier to slide in place. Noticed that its installed on your photos.
David Rohrlick
PPSEL A&P
Serial#12-0864
N864DR Reserved
Old 02-19-2018, 03:55 PM
They tell you to leave the one hole open and that was fine.
I ended up flipping the thing over and working on it right side up on the workbench and with a little finagling, got everything to fit fine.
Bob Collins
St. Paul, MN.
Builder log
