Old 02-18-2018, 09:12 AM
n4322b n4322b is offline
Default Firewall Cable Locations / IO360 (Vertical)
I am trying to get as much work on teh firewall done as possible before I mount the engine and would appreciate anyones' experiences with the Vans suggested locations for the control cables.
For a vertical throttle body (IO360 B1B with airflow perfromance throttle body) the manual suggests to use the carburettor related locations for mixture and throttle.
How did they work out and were the "standard" control cables sufficient in length ?
Ian
Old 02-23-2018, 06:50 PM
jmjula's Avatar
jmjula jmjula is offline
I have an AFP FM-150 and this is what my firewall looked like before installing engine:
https://drive.google.com/file/d/0B0S...ew?usp=sharing
The lower hole by the main fuel fitting is throttle, and the one up and right slightly is mixture. I am pretty sure I had the mixture cable for IO, and it is longer than it needed to be. I did have to modify the cable attach bracket on the engine for the mixture.
James Jula - CFI/II/MEI - N713JL RV-7A First Flight 10/12/15 - "What is chiefly needed is skill rather than machinery." Wilbur Wright, 1902
Old 02-25-2018, 02:15 PM
That's great - thanks. The vans drawing would I think, have mad me put the mixture higher still and didn't seem right.
cheers
Ian
Fuji FA200 / 160 - sold
Sonex - Aerovee - Sold
RV7 in build
Old 03-04-2018, 10:19 AM
kentlik's Avatar
kentlik kentlik is offline
James, did you rivet the center rib structure to the firewall later?
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-05-2018, 03:52 PM
jmjula's Avatar
Kentlik, if you mean the two rivets up in the middle to the forward sub-panel rib, then yes, that was done once I made the cuts to the sub-panel for the radios and was ready to rivet that in place.
