Old 02-16-2018, 08:38 PM
wfinnell wfinnell is offline
Default 90 deg oil filter adapter?
Hi Guys,
I'm buying an engine for my RV-8. There is an option for a 90 degree spin on oil filter adapter. I imagined that this would position the oil filter in a hanging down position, making filter changes easier.
I did a google image search and it looks like it points the filter up...
So now I'm thinking, maybe the oil will drain out of the filter while it is still attached to the engine.
I searched the forum and couldn't find the answer to my questions, so here goes:
1) Do I have it right, does the adapter point the filter up?
2) Is this a good option? Does it help with oil changes?
3) Does it get in the way or cause any interference under the RV-8 cowel?
Thank you in advance,
Bill Finnell
RV-8 Fuselage
Tucson AZ
Old 02-16-2018, 10:17 PM
Planecrazy232's Avatar
Planecrazy232 Planecrazy232 is offline
#1 yes it points up. I poke a hole in the filter when I begin my oil change and itís empty by the time I get the bottom cowl off and drain the oil and check the screen. Spinning the filter off is the last thing I do and itís virtually mess free.
#2 itís a great option. I did it after several messy oil changes in the stock position.
#3 not sure I have a RV6.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018 donor and happy to do it.
Old 02-16-2018, 11:51 PM
I have one that the oil filter hangs down. I can't remember the name but I thought they were supposed to joint up so I called the company and they confirmed it hangs down. If you want the name or a pic, email me and I will get it when I get home in a couple days.
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
Old 02-17-2018, 04:24 PM
Daida Daida is offline
Default It works, but....
1.) as already said, pointing up.
2.) i am not flying yet, but i searched the forum and decided to go with it exactly for that reason. To ease oil changes and make them less prone to make a mess. (Planecrazy232 desrcribes the way to do them)
3.) no issues with the cowling, but the engine mounts upper left tube is getting in your way so that the Filter wonĎt come off (conical mount, ECI Titan XIO-360). You have to order the spacer with the filter adapter. For me the 2.5Ē spacer from B&C worked perfectly, i also ordered the filter adapter there, if i remember correctly (www.bandc.aero).
Mit FliegergruŖ
RV-8 QB Germany
metal work complete
ECi XIO-360 installed
Dynon SV
Wings+Empenage+Fuselage=Plane
Working on glass-thingies
Almost there!
