Old 02-15-2018, 06:19 PM
Jshepherd Jshepherd is offline
Default New section 10 plans posted
Looking at the new section 10 plans for 12is tailcone assembly, only difference I can see is an inspection hole and cover in the forward end of the tailcone. Hope itís not important for those of us with tailcone built already
Old 02-15-2018, 07:00 PM
rv9builder rv9builder is offline
It is important if you're building an iS fuselage. The hole is where the fuel drain goes. My guess is that they will have some sort of retrofit kit to add an inspection hole and cover to Generation 1 tail cone kits that are being used with iS fuselages.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 02-15-2018, 07:32 PM
Thatís the boat Iím in so I hope they do
Old 02-15-2018, 07:33 PM
rolick22's Avatar
rolick22 rolick22 is offline
Talked with Vans today there will be a mod kit later on that can be used for builders (like me) that have the old style F-1283A skin.
______________________________________
David Rohrlick
PPSEL A&P
RV-12 Finished (Empennage, Fuselage(1st gen), and Wing kit)
Empennage finished (need to add the panel cut out)
Wings finished (need to add the left landing light)
iS Finishing Kit In work
iS Fuselage Finished
1st GEN FUSELAGE SOLD
Serial#12-0864
N864DR Reserved
