  #111
Old 03-12-2018, 08:33 PM
I got the bolts in from the top using forceps to get them into the hole. I set up my endoscope so I had a good view to manipulate the bolts. It also helps to chamfer the last 1/8 of the bolts so you can tap them into place. The spacing washers are a challenge. I used the endoscope to estimate the spacing with the stab centered. Then I pulled it off and super glued the washers in . It worked well, but it really hurt taking the stab off to do it after going through the gyrations to get it reattached to determine the spacing. The control cable turnbuckle locking clips are a pain because the alignment has to be perfect to form the groove for the locking pin.
Old 03-12-2018, 09:56 PM
DaleB's Avatar
DaleB DaleB is offline
We got the stab re-installed and cables reattached tonight. We'll need to install some washers between the brackets and bearings, but I'm pretty sure I'll be able to get them in with my washer wrench. I hope so, anyway.
There were no washers there before. Don't know why, maybe they weren't needed.
Dale
Omaha, NE
Previous RV-7 project (sold)
-=VAF=- 2017 dues paid
Old 03-13-2018, 05:33 PM
DHeal DHeal is offline
Just completed my Stab SB and offer a few observations on the stab reinstall:
1. Van's suggestion to instant-glue the original configuration washers to the new brackets worked great -- be sure to abrade the gluing surfaces for max adhesion and use a touch of grease to help the brackets/washers slide onto the bearings. CNC accuracy and Van's engineering are amazing in that my original washer configuration perfectly fit the new brackets/bearings.
2. Find two friends to help you position the stab. Alternatively, you can build up a table or sawhorses to get the stab in position -- the stab reinstall can then be a one-man job.
3. Forceps or long-handled needle-nose pliers working from below can be used to initially position the bearing bolts. A set of extensions for your socket set is necessary to final install and torque the two bearing bolts.
4. See Scott Millhouse's earlier post (#110) regarding the reinstallation of the stab cables -- that worked fine for me. Thanks Scott for the tip.
5. There is the potential to scrape the forward portion of the stab against the aft sides of the tail cone when you initially remove and replace the stab. Tape some protective sheet plastic or heavy paper in these areas to prevent scratching.
I wasn't looking forward to the stab reinstall but it took less than 30 minutes and went according to plan -- Yeah!
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 670+ hours (as of Sept 2018)!
VAF donation through June 2019.
Old 03-13-2018, 07:27 PM
DaleB's Avatar
One tip: We found that by putting the stabilator in place with the HS-1210 hinge stops contacting the F-1211C hinge bracket (upper or lower, whichever works for you), the bearing bracket holes were trivially easy to line up for the bolts to go in. It just puts the stabilator in the right position for everything to line up.
Dale
Omaha, NE
Old 03-16-2018, 10:32 AM
kevinl4000's Avatar
kevinl4000 kevinl4000 is offline
Has anyone done any detailed write-ups on their builder's blog on the Stabilator SB? Asking for a friend.
Kit #120-666 "The number of the beast"
http://kevinsrv12build.blogspot.com
Old 03-16-2018, 05:09 PM
pstraub's Avatar
pstraub pstraub is offline
Hi Kevin, no detailed write up here, but I can tell you it took me about 12 hours, it involved more than I initially thought. Here is the completed image, this is the top view, the bottom is basically a mirror image of the gussets and the stabilator horn. Glad I did this before painting. You throw away the old hinge brackets assemblies.
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
120 hours and counting.....
Old 03-16-2018, 05:32 PM
kevinl4000's Avatar
A picture is a thousand words. Thanks, Paul
Old 03-17-2018, 04:06 AM
BigJohn BigJohn is offline
Thanks for posting that nice clear picture Paul. Makes it much easier to viualize the task ahead.
VAF paid through 10/2018. Best bargain in town.
Old 03-17-2018, 08:32 AM
LittleJoeA LittleJoeA is online now
Paul,
Thank You very much for the excellent Photograph.
Joe
Joe Arluck
Livermore, CA
RV-12, S/N 120419
Empennage/Tailcone finished
Wings finished
Most of Finishing Kit finished
"It's sitting on the Landing Gear"
Engine mostly installed
Avionics Kit in Hand
Currently fitting wings
Paid 2018
Old 03-17-2018, 11:10 AM
pstraub's Avatar
My pleasure guys. Here is another one that may help. This is the bottom view. By the way, great to see your name Joe! It's been almost 2 years since your 'open house' at LVK, and your RV-12 was almost complete. I wondered what happened to you, hope all is well. Paul
N917PB, SN 120971
