Old 02-14-2018, 07:40 PM
KazooRV-9A KazooRV-9A is offline
Default What Gascolator backing plate?
I have the Van's accessory catalog gascolator. what backing plate do I need for installation in my RV-9A?
I see pictures of this massive plate that spans the angles of the firewall, do I really need such a big plate for just the gascolator? If so, what's the P/N?
AC.
Old 02-15-2018, 08:17 AM
Ralph Inkster Ralph Inkster is offline
VA-161
Yes you need it to stabilize the flexing motion from engine vibration transmitting into the firewall & causing cracking. Also if the gascolator has aluminum lines running to it, you don't want any fatigue cracks forming there either.
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 02-15-2018, 08:43 AM
Mike S Mike S is online now
One thing-----be sure you are using the correct in/out ports.
There is a gascolater out there that feeds from the rear mounting flange, not sure if it is the one Vans sells or not.
See this thread. http://www.vansairforce.com/communit...ght=gascolator
Old 02-16-2018, 04:13 AM
Great. I found the P/N for the gascolator brace, it's on order from Van's.
Tnx,
Andy C.
Old 02-16-2018, 09:26 AM
There are 6 different iterations of the gascolator produced by Usher Enterprises and sold by Van's over the years.
GAS-1 through GAS-6
As shown by the thread Mike linked to, it is important to know which one you have when installing it.
Scott McDaniels
Hubbard, Oregon
