Old 02-12-2018, 04:09 PM
Bavafa Bavafa is offline
Default Stall warning kit in the wing
Just wondering how many people are installing the stall warning kit that comes with their 14 kit if they are planning on installing AOA? This is one of those redundant part which I am debating to install it or just suffice with the AOA that comes with G3x system
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Phase one
Dues paid
Old 02-12-2018, 04:11 PM
bkervaski's Avatar
I'm going with AOA only, I don't think I even received a stall warn kit from Vans?
Progress: Flying!
Old 02-12-2018, 04:55 PM
azflyer21 azflyer21 is offline
When I ordered my qb wings I asked to delete the stall warn parts and Van's told me this is flight critical and cannot be omitted. I'm still going to omit this and use AOA.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
Old 02-12-2018, 05:18 PM
BobTurner BobTurner is online now
Since the AOA systems usually need in-flight calibration, you might consider installing the factory stall warning system for the first flight(s); remove it later if you wish.
Old 02-12-2018, 06:05 PM
KeithB KeithB is offline
I have AOA (Garmin) but opted to keep the Vans stall warn (it was in the wing kit). My reasoning was that since the hole was already cut in the leading edge skin, filling it in would likely look worse than having the stall vane - connected or not.
I then opted to connect the stall indicator to the Garmin GAD 27 on a discrete input. The GAD 27 is set up to activate the Master Alarm (red light) in the crew alert system (CAS) in the G3X. Originally I also had an audio alert in the G3X but I have since turned that off (simple software setting) and if I want, I can deactivate the red light by just changing a setting in the GAD 27 (or G3X).
I have the AOA calibrated and I find the stall warn (Vans) goes off well before reaching critical AOA.
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, >375 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 02-12-2018, 06:15 PM
I think this is a good plan that I might go with. My kit has only two small hole in the leading edge as a template that I need to use to cut the slot for the vane. I just don't like the vane tab sticking out and removing it later is not good option for me since I will have a slot in the leading edge open.
some times having too many options is not a good thing
Mehrdad
Dues paid
Old 02-13-2018, 12:07 AM
control control is offline
I will not use it and filled the holes with rivets. You will probably not be able to tell that they are there after scuffing/priming/painting
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 02-13-2018, 08:26 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
I put a bid of glass on the inside over the holes, the holes themselves had some micro before the glass. After set up sand the mico flush with the skin and paint.
Old 02-13-2018, 09:53 AM
Does anyone know if they can be calibrated for accuracy?
Mehrdad
Dues paid
Old 02-13-2018, 11:26 AM
If by they you mean the vane type stall warning?
Yes, they can.
The way they work is that the switch trips when the stagnation point on the leading edge of the wing switches from hitting the leading edge at a point above the vane to hitting a point just below the vane.
Or in simpler terms, when the relative wind transitions through the point where the relative wind switches between hitting the top side of the vane (and holding it in the down position) at a particular angle of attack, to hitting the bottom side of the vane and causing it to lift.
So if you adjust the bend angle of the vane, the switch will occur at a different angle of attack.
If you need the warning to come on at a slower speed (higher angle of attack), you need to bend the vane downward.
If you need the warning to come on at a higher speed, you need to bend the vane upward.
In most airplanes, it should actually be referred to as a pre-stall warning. There is no point in warning you that you are stalled.... you probably would already know at that point.
The typical setting is for it to activate at 5 - 7 kts above stall AOA.
Scott McDaniels
Hubbard, Oregon
