Old 12-17-2017, 07:15 PM
czechsix's Avatar
czechsix czechsix is offline
Default Break edges of skin around aft window?
For those who have fitted the aft window, did you find it necessary to break the edges of the upper skins (F-01474-L and -R) where they meet the plexiglass in order to get a nice fit? Plans don't mention this when building the tailcone, and if needed I'd rather do it before painting the inside of the skins (I paint interior parts prior to riveting).
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 12-17-2017, 11:04 PM
Jake14 Jake14 is offline
I did, but very slightly. Seemed to help, especially along the top. Best to do it before you dimple, but I imagine most folks have already dimpled at that point
RV-14A #140158 flying
Old 12-18-2017, 12:12 AM
control control is offline
I did so, needed?
RV-14 kit #140138
working on FW forward and finish kit
wings, tail kit and fuselage basically done
Http://magnusrv.blogspot.se
Old 12-18-2017, 05:41 AM
Tom023 Tom023 is offline
Yes the plans call for it. See p38-03 step 13. I found it difficult to break the extreme forward edges near the roll bar.
RV14A #140083
Wings, empennage, fuselage and finish slow builds completed
FWF and avionics in progress
2017 Donation
Old 12-18-2017, 08:54 AM
Bavafa Bavafa is offline
At least during the construction of the tail cone, the instructions says not to dimple and no mention of edge break for this area. I guess I need to double check those pages. Remember, this part does not get riveted but screwed, there will be a thin layer of proseal or other type seal used for water proofing and you want an straight skin so the aft canopy part can easily slid in-out for fitting.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 03-10-2018, 05:43 PM
Bernard Hartnell Bernard Hartnell is offline
Default Roll edge with special roller tool only!
It was not possible to roll edges top center due to longatudinal bar over luggage compartment. But plexiglass window will seal better with proseal if edges are rolled as possible. Practice on scrap first to be sure you like the result. Change tool if needed.
Old 03-10-2018, 06:13 PM
bkervaski's Avatar
Mine was already dimpled at that point but I still put a very slight break on the edges. Turned out good but would have been better if I had done it before the dimpling.
Progress: First Flight Prep
