Old 12-15-2017, 12:57 AM
KRviator's Avatar
KRviator KRviator is online now
Originally Posted by kaber56 View Post
I apologize if this thread is redundant but does anyone know of an easy software program that can be used draw up my electrical system?
From an earlier post of mine regarding the Digikey SchemeIt online tool:
By their nature, pilots that fly on their own ruble are always looking to save a dollar here and there. Those of us building planes are usually looking for ways to do things smarter, better, and faster. Put the two together and you tend to wind up with some pretty talented people.
The time came to finalise my as-built electrical schematic and rather than try to hand-draw it a bit of searching online found DigiKey has a free, online tool that will allow you to do any number of drawings, complete with a database of electronic components so it looks just like it came from Stein!
It will export into PDF or PNG format, save it (if you're a registered user) for later use, print and even go so far as to compile a bill of materials for their own webstore, it's a pretty nifty tool all round.
Here's the website, enjoy!
And as a rough example, here's my complete electrical system after around 6 hours of research and drawing - including the first 3 hours lost after I didn't save it... You have the right side SkyView, ADAHRS, GPS and EMS modules, an Xcom VHF and a VP-X Sport as well as 2 PMag's, with all the wiring in the plane shown on the diagram.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A 19-8519 - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Phase I done. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 12-15-2017, 08:35 AM
kaber56 kaber56 is offline
Default Thanks!
To all who posted thanks for the info. I think I will try ExpressSCH. This forum is worth its weight in gold!
Old 12-15-2017, 06:55 PM
gear1 gear1 is offline
Default Creating Electrical diagam
I was not aware of the neat programs available when I did my new Dynon HDX based panel, including ADSB in and out. However I do know how to use spreadsheets, so I used ExCel to create a plan.
On the left side of the spreadsheet, I listed all of the component plugs, then using the columns to list each component plug pin number, the color of the wire, size of wire, and any intermediate plug or connector then on to the destination of that specific connection, whether it be to another plug or to a component such as the landing light. So each connection was shown as a row on the spreadsheet.
By listing all plugs on the left side of the spreadsheet, I could easily see where a wire started, and where it arrived.
Wiring of all of the system was easy. I just decided what plug to start with and worked my way down the spreadsheet, running one wire at a time till I had all of the wires installed in the aircraft and connected.
Another advantage of this system is that it became self checking - as I worked my way down the spreadsheet list of plugs, I would come upon wires that were already installed from another plug higher on the list, and took the opportunity to double check that wire.
The system also allows for easy trouble shooting. I keep the spreadsheet on a thumb drive in the aircraft in case of problems on the road.
It is probably not the best system, but it certainly worked well for me, and I did not have to learn any new software (old dogs and new tricks....)
Craig Taylor
RV8 flying
2018 VAF dues paid with thanks
Navy A7E Viet Nam era
Ret. Corprate Pilot: G1159, IA Jet, Jetstar, Falcon 10, 20, 50
Old 12-15-2017, 11:10 PM
Wunderon's Avatar
Wunderon Wunderon is offline
used Dassault https://www.3ds.com/products-service...free-download/
Dave Grimmer
RV8 firewall forward
EAA 84 Edmonds WA
paid 2018
Old 12-16-2017, 05:35 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Need help on Express SCH
I have downloaded and all I get is PCB. The support desk says SCH is there as feature in PCB 😏 Can anyone direct me to the basic SCH that can be used to replace my pencil ?
Signed: Digitally Challenged Larry
Larry DeCamp
RV-3B flying w/ carb & Pmags
RV-4 fastback w/ Superior EXP 0360 /AFP & CPI
Clinton, IN
Old 12-16-2017, 09:56 AM
Snowflake's Avatar
If I recall, both packages are installed at the same time, but ExpressSCH is a different program... You have to start it from the Windows Start menu, not from within ExpressPCB.
Rob Prior
Old 12-16-2017, 11:41 AM
vlittle's Avatar
vlittle vlittle is offline
Rob is correct, for the classic version. I am now downloading the plus version and will report back.
Update: the plus version enhances pcb layout only, the schematic editor is essentially unchanged.
Find it in the Windows Start menu and add a link to your taskbar for convenience.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 03-03-2018, 09:06 AM
jaybob jaybob is offline
Default Jump starting schematic
Used TurboCAD on my last project but don't recommend it. I hate the idea of starting over from scratch. Does anyone have a few example ExpressSCH source drawings they can share? PM me please.
Thanks!
Jay
RV-9 Builder
Old 03-03-2018, 10:17 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up Each to their own
Thanks!
Jay
RV-9 Builder
I prefer TurboCAD and find it useful for other, non-schematic uses, such as making final panel shapes with cut-outs to send to Up North Aviation for fabrication.
If you use TurboCAD make sure you have a nice size grid turned on and the lines will snap nicely into place. The "Rubber Stamp" function is easier and quicker to use than "Copy".
Personal preference, but I prefer smaller multi-sheet schematics that I can print at home on my tabloid size printer. It does need a consistent sheet-to-sheet labeling system to be created and used. I was told this was the way the Navy likes their schematics since they didn't have room for the industry standard E-size paper (34 x 44 inches) on board a carrier. A B-size (11 x 17 tabloid) PDF is also easier to read on a laptop screen.
If anyone is using TurboCAD, I have a sheet of symbols and a few sample sheets already made that will speed up the schematic drawing process. Private email will get you a copy.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-03-2018, 09:20 PM
bluskydreamin bluskydreamin is offline
Default expressSCH fuse block symbols?
any ideas where to find ready made ATC fuse block symbols 6,8,10,16,20 position etc. for import into expressSCH? have searched the custom files online but cannot locate. tried drawing and cannot maintain accurate scale from slot to slot.
Thanks!
