Old 05-26-2015, 12:01 PM
wirejock's Avatar
wirejock wirejock is offline
Default Skin to longeron to F-711 rivet
New question. Drilling skin to longeron holes and found one virtually impossible to set.
How did you all set that one rivet on each side? It's going to be right up against the F-711D angle.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-26-2015, 12:24 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
The F-711D angle gets riveted after riveting skin to bulkhead. I reached it by using a tungsten bar with my arm thru the top the of the deck. Not as bad as it may seem.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 05-26-2015, 12:36 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Thats not the last one you'll run into on the longeron, either. Wait til you work your way forward to the 704, I think. There is a rivet there that I didn't have a bucking bar capable of setting.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
rvblog.thebrices.com
Old 05-26-2015, 04:26 PM
wirejock's Avatar
Default F-711D
I riveted the F-711D angle in place. Sounds like I should drill it and remove it till later.
Confirm please?
Larry Larson
Estes Park, CO
Disclaimer
Old 05-26-2015, 05:56 PM
terrye terrye is offline
Default F-711
Yes, I just did this. Remove the F-711 angle, rivet the skins to longerons to bulkheads and reinstall the F-711 angle.
Terry Edwards
RV-9A (Fuselage)
2018/2019 VAF Contribution Sent
Old 05-26-2015, 06:04 PM
Confirm please?
If it's just the one rivet on each side why not put in an MK319BS (or similar) blind rivet and move on? It's under the HS so no one will see it unless they're looking for something out of place.
Carlos in Arizona
Old 05-26-2015, 06:30 PM
wirejock's Avatar
Default Rivet
I would but there's no room for any shop head. I will have to remove it (2 rivets) and modicy it a little so those two shop heads will clear. No worries. Easy to drill two rivets. The hard part is remembering to do it. I already stuck a post it note in my log.
Larry Larson
Estes Park, CO
Disclaimer
Old 05-26-2015, 10:27 PM
TCONROY's Avatar
TCONROY TCONROY is offline
Problem with that particular rivet is when you go to install your emp fairing. The drawing calls for a screw right there. I talked to Van's and they said I could drill the rivet out, tap the longeron, and leave the inner rib hole empty.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
First Flight - April 12, 2015
Construction Log
Old 05-27-2015, 06:13 AM
dbaflyer dbaflyer is offline
I wouldn't drill out the F711. You might cause more damage needing more fixing. This is a "known" issue with the QB fuselage. After going around with Van's I ended up buying some special length pop rivets that worked. MK319 are too short. They had to be set gradually and pushed in as I went. I have no screw there for the fairing.
Denis Sailer - Eastern Iowa
RV9a builder - Finish Kit in progress
Old 05-27-2015, 08:50 AM
wirejock's Avatar
Default Thanks
Thanks everyone. Lots to consider.
There's no room for a screw or rivet unless the angle is removed and the ends relieved a tiny bit. I will give it a good look when the fuse is disassembled for prep work. At that point the bulkhead will easy to access without the longeron installed. I should be able to drill the two rivets no problem.
Larry Larson
Estes Park, CO
Disclaimer
